Old 03-07-2016, 06:50 PM   #11
Tireman9 does the added weight of the hoses or TPMS sensors require tire balancing? Did you mount the TPMS sensors before the hoses (at the metal valve stem)?
Wrightwood is offline   Reply With Quote
Old 03-07-2016, 08:23 PM   #12
Commercial Member
No re-balance required with hoses or TPMS or both installed. As a professional in vehicle rife & handling evaluation I have a trained and educated butt and I do not feel any difference. The hoses on dual counter-balance much of their weight.
If you have full wheel covers you can still attach the hose end bracket to the center section of the wheel simulators.
I will be posting new picture soon.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 03-20-2016, 07:09 AM   #13
dually valve extensions
Tireman9
Have you had any experience with installing a Crossfire system on MH with wheel simulators & if so any info would be appreciated
2016 Freelander 26RSF
2015 Jeep wrangler sport toad
jjrver is offline   Reply With Quote
Old 03-22-2016, 09:58 PM   #14
Commercial Member
Personally I see no advantage but do see some disadvantage to Crossfire system.
When you set the pressure in your dual tires you can set to +/1 a couple of pounds which is plenty accurate enough.
If one tire develops a leak it will continue to loose air till it goes flat. The Crossfire will only transfer a few psi before it shuts off. This means the tire that now has to carry most or all the load has had some of its air bleed off. Not a good thing.
IMO a MUCH better investment is in a TPMS which will warn you if you develop a leak so you have time to do something in most cases.
wheel
