Old 04-21-2019, 11:47 AM   #1
Emergency window leaks
Hi everyone,
We just got a Coachmen Mirada 35bh in February. Recently in heavy rain and the bedroom emergency exit window had heavy condensation on the inside and a water leak filling the sill and spilling onto the floor. Your thoughts?
Thanks ,
Tom
irish01 is offline   Reply With Quote
Old 04-21-2019, 12:47 PM   #2
Check for drain holes/slots in the bottom outside of the window frame. If they're plugged water will back up into the interior.
stephndudb is offline   Reply With Quote
Old 04-21-2019, 02:48 PM   #3
Were you running the propane heat or cooking inside without exhaust? RVs are known to have lots of condensation on cold days with propane heat going. Propane gives off a lot of moisture when burning.
2015 Ford F150 Platinum 3.5L Ecoboost
2015 Rockwood Ultralite 2604WS
No longer mine: 2006 Rockwood Roo 23SS
mjbenedict is offline   Reply With Quote
leak, window
