08-30-2015, 01:46 PM
Encounter
My wife and I are considering buying a 2016 Encounter. Would like to know what is your experience if you own one?
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
08-31-2015, 10:10 PM
Anyone with an Encounter out there?
09-01-2015, 08:56 PM
Encounter
Yes, there are a few of us. We have a 2013 Encounter 36KS. Have had a few warranty issues that have been resolved - some at the dealership and others at the factory or a Service and Seminar Rally that we attended in 2013. Pretty reliable now and handles very well. Last weekend we ran into a driving rain on the way home and discovered that the front clearance lights leak. Spent several hours taking them apart, cleaning and applying silicone sealant.
We live in ours 4 to 5 months a year. We like the floor plan; however, the DW would kill for a washer/dryer - maybe our next one...
Have done lots of mods including: inverter, BIRD, LED strip light under awning, replaced all halogens with LEDs, cheap handling fix (CHF), 5 Star Tune, transfer switch, toad charging circuit, beer fridge in basement, vent covers, upgraded home theater/DVD system. I am an electrical engineer and do my own RV repair/mod stunts...
What else would you like to know about the Coachmen Encounter/Ford F53 Chassis?
LLVanB
2013 Coachmen Encounter 36KS, 2020 Chevrolet Equinox toad, Roadmaster Falcon 2, Brake Buddy Vantage Select, Protect-a-Tow, 5 Star Tune, M4 LED lights, BIRD, ATS, Xantrex PROwatt 1000 SW Inverter and many other accessories & mods.
09-02-2015, 11:26 AM
Thank you for your response. I just wanted to hear from some owners about their experience.
09-02-2015, 08:52 PM
2011 Encounter 37TZ here. about 15,000 miles now, combination of local time and trip time. We have one of the first Encounters (37TZ anyway) off the line and as you might expect many many issues but... once we (the dealer and I) got to them, the DW and I started to have more fun with the rig. Now I would take it anywhere.
My suggestions, come to grips with these limitations: no washer or dryer, small shower (get in it and close the doors so you know what you are dealing with) no heated tanks or wet bay so this is a three season coach, small grey water tank meaning if you don't have full hookups you have to conserve water so as not to fill the grey tank too fast. Fresh water and black holding tanks are fine, its the gray that is too small.
Service is mush less expensive than Diesel coaches, fuel costs right now are low but regardless fuel mileage is also low. We tow a jeep and I load the coach up; we get 8mph sometimes on the level and as low as 6.5mph in the mountains when towing and we are always towing.
You may want to add a steering shock and rear track bar to improve handling on the Ford chassis but otherwise the Ford Triton engine and chassis is just about bullet proof.
Hope that helps,
Gary
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2018 Wrangler Unlimited Sahara (JKUS). Many upgrades, additions, mods, and changes to the coach.
09-02-2015, 10:05 PM
Well, two of the floor plans 37LS and 37SA come with washer/dryer prep. We are thinking about this. Thanks.
09-02-2015, 10:06 PM
Gary, how does it pull the Jeep?
09-03-2015, 08:42 PM
We have a 2012 Wrangler Unlimited (meaning a 4 door) weighing in at about 4012 pounds if I recall correctly.
Much of the time we don't even know it's back there. But going up grades you start to feel the weight. We slow down to 50 or so on long grades like Fancy Gap in the Appalachian Mountains.
I was told by a gentleman I met recently who has a gas Newmar Canyon Star that he slowed down to 25-30 by the time he got to the top at Fancy Gap and 50 was doing very well. The Canyon Star he was driving was another 24/30 inches longer than our 37 TZ which is not quite 38 feet.
You'll pick up a little tail wag on curves when towing due to the long overhang on longer gas models but the track bar previously mentioned will mitigate much of it. The problem is the long overhang and leaf spring set up on the Ford. The Axle moves left and right slightly enhancing that tail waging the dog feeling. Again, get a rear track bar, it will hold the axle in place. This is not an "Encounter" problem by the way, it's a problem with any brand of longer gas coach on the Ford Chassis.
Gary
09-04-2015, 11:22 AM
Thank you.
09-04-2015, 09:14 PM
Think twice before investing in a Coachmen. We bought a 2015 Encounter 37LS 50th anniversary edition in January. It took 8 months before we could use the unit. It spent most of that time at the dealer or at the factory.
Both drivers and passenger windows had to be replaced
Front cap had to be reattached and resealed
Windshield was resealed 3 times
Stairs had to be replaced
Slide seals were replaced
The residential refrigerator died, dealer wouldn't touch it, the factory finally swapped it out but in the process had to rebuild a wall of cabinets because the new refrigerator was bigger than the original one.
The light fixture above the mirror in the rear bathroom fell off the wall while we were driving to the factory. Mirror didn't break but had to be replaced. In the process of replacing the mirror they mounted it differently resulting in it sticking out a little bit from the wall. You can't see this at all. No big deal right? Not exactly. The bathroom sink faucet is offset. It's a 2 lever faucet and when you turn the hot water off the lever hits the mirror. I have to replace the faucet with a single lever unit.
At the same time when they reinstalled the light fixture they left a wire hanging outside the housing. I have to loosen the fixture and push the wire back in.
The entire outside had to be resealed. The factory put the unit in the rain tank to test for leaks. It was done with the slides in and out. The also found a leaking backup light, they replaced both.
Both coach batteries had to be replaced and the chassis battery is on it's last legs, it will get replaced next year.
The awning was wired to the chassis battery instead of the house batteries resulting in the awning going out but couldn't retract. I had to do some rewiring to fix that.
When we went to put in the water filter into the housing (just before our first trip) it leaked. Couldn't figure out why. Finally realized that it was installed without the o ring. It's a special size, no one anywhere had one. Only fix was to put a new housing in which I did do we could take our first trip.
Overall it's a well built unit with a few issues. It has what we want, just wasn't built right. That sours our opinion of Coachmen even though they stepped up and fixed most of the problems.
09-05-2015, 08:29 PM
We got a 36BH in February. Had a number of issues. Roof leak, ceiling sagging, cracked tile, and a couple of other minor issues. Returned to dealer, MHS in Alvarado, Tx. All taken care of professionally. Now I have discovered that both front fenders are split, broken at the mounting bracket. I have sent pictures and we will see how this plays out.
We really like the coach. For as much stuff that it has, so much is working great, without any problems. I mean really, it's a motorhome, stuff will always need attention.
09-11-2015, 03:00 PM
Captain Frank
We just purchased a 2014 Encounter 37LS. Had the same front dash leaking problem. We added a washer and Dryer unit causing the Passenger side rear to sag due to the extra weight. Remember, the generator and refrigerator are on the same side. Looking into either air bags or heavy duty shock on that side. Will be taking it out on maiden voyage this week. Will know better once we spend some time in the coach.
09-11-2015, 03:59 PM
The Generator is on the passenger side? I thought they were always on the drivers side with the engine exhaust; away from the door.
Gary
09-11-2015, 04:09 PM
Captain Frank
Encounter 37LS generator location
Nope. The generator is on the passenger side rear of the 37LS with the exhaust going under the coach to the drivers side rear. Still doesn't answer my question about the air bag installation. Any thoughts?
Frank
09-11-2015, 04:14 PM
I had bags on previous class c and now on our Encounter 36BH because of the improvement in ride quality. I didn't have leveling issue but bags can't hurt. Be sure and get the compressor/inflator with control mounted by dash so pressure can be adjusted accordingly
09-12-2015, 08:16 AM
Let us know how the fender fixes go. I just found a crack in my drivers side rear bracket. The rest are good for now. Debating if I should wait until they all crack or fix them one at a time myself. Yes could go to the dealer or factory but unless it's major work I'm not bothering them.
09-12-2015, 08:37 AM
That dash leak will drive you nuts, won't it? I knew exactly where it was coming from but the dealer kept telling us it was from the roof, wait, no, the windshield, maybe it's the front cap. Guess what, it's your window that's leaking. What a nightmare that was.
Skip the air bags and heavy duty shocks. The heavy duty shocks will only make the ride worse. Get the RV to a truck spring shop and have them either add a leaf to the spring packs or make you a new set. It's a much better route to go. Then you can add Sumo springs and a rear track bar if you haven't already. You don't need both at the same time, you should start with the rear track bar first then the Sumo springs. The track bar will help when trucks are passing and in side winds. Also, if you don't have a steering stabilizer add that to the list, I prefer the Steer Safe unit.
SteerSafe.com | Superior Steering Control
SuperSprings > View all suspension options for your vehicle
SuperSteer Trac Bars - Ford F53 Motorhome Chassis – Class A
09-12-2015, 08:56 AM
Frank
On my 2015 the generator exhaust goes straight back on the passenger side. Under the bedroom and bathroom. What I can't figure out is why no one in the RV industry has ever run the exhaust up the inside of the back cap and out the roof. Yes, it would cost more. They would have to design a fireproof chamber for the exhaust pipe but couldn't it be done? It might put a big dent in Genturi sales.
09-14-2015, 12:02 PM
How did you fix the leak?
09-14-2015, 06:27 PM
Coachmen replaced both windows. Everything was replaced. Hehr made the windows I have. They said the windows were rebuildable, meaning the window comes completely apart and new seals were put in. Considering how new my RV was I said no to the rebuild and requested new windows. The dealer said it takes many weeks to get replacement windows, Coachmen had them to the dealer in less than a week.
