Old 01-09-2014, 10:02 PM   #11
Ford Idaho's Avatar
Originally Posted by Lindan View Post
FordIdaho we did as you said and yes the fan went off as well as lites, etc.
But when we have family stay over we turn everything back on to have lites the fan blows 24/7 even when the heat/ac switch is off.
Like I said before, this has never happened before. Do you think the thermo is broke?
ty
Could be.
I would put a multimeter on it.
Check the links in this thread.
Defective Furnace? - Page 2 - Forest River Forums
Tons of info on testing and replacement.
Old 01-09-2014, 10:06 PM   #12
Ford, I will read and check the furnace posts.
Thank you
Lindan is offline   Reply With Quote
Old 01-09-2014, 10:15 PM   #13
Ford Idaho's Avatar
Thank you
I have done nothing yet.
Please do post back with your findings and fix if you can.
Old 01-09-2014, 10:38 PM   #14
Mr. Ford, I think that you did, you pointed me into the direction for more info. I will post again if we fix it or find a solution.
Old 01-09-2014, 10:52 PM   #15
Denver, CO
garbonz's Avatar
The furnace is 12 volts and you can pull the fuse in the distribution center.. Same as an automotive fuse and the panel should be labelled. That way at least you can use the electrical system, while you get er fixed.
2017 Fuse 23T
garbonz is online now   Reply With Quote
Old 01-10-2014, 12:20 AM   #16
bikendan's Avatar
ty
many of us replace that crappy Dometic analog thermo, with a digital one, such as a Hunter or Honeywell thermo.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-10-2014, 05:43 AM   #17
Former Full Timer
Duckogram's Avatar
LinDan,
You have some good responses and a direction to head in. The only thing I would add is to leave the coach plugged in to 110v with the battery disconnect on until your house batts are fully charged then turn the disconnect switch off so the vampires don't kill your batts.
Good luck with the fix and please do post what you find to be the causal factor.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 01-10-2014, 07:50 AM   #18
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
It might be a defective thermostat. Being an analog thermostat with mechanical switches, there might be a defective/dirty/oxidized switch. Try moving each switch back and forth several times real fast. If this should correct the problem, a new (hopefully digital) thermostat may be called for.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 01-10-2014, 09:07 AM   #19
jonrjen's Avatar
Here is my suggestion for what it's worth. Your Screen name says your location is So Cal., if you would care to narrow down your location maybe a member here would be willing to stop by and give you a refresher course on how things work, where various controls are located, and share a few time learned educational experiences with you. Most RV folks are more then welcome to help one another out.
Just a thought,
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 01-10-2014, 06:49 PM   #20
litgrep's Avatar
If you turn the propane on and bump the thermostat up to about 70: does the heat come on? If it does, flip the furnace switch from off to furnace then back to off. Turn the thermostat back down all the way. The heater will run until cool down then should turn off. If it doesn't, bad thermostat switch. Pull fuse to turn off and have the thermostat fixed or replace. There are several threads on the forum replacing the thermostats with digital ones from Home Depot.
2013 Salem Hemisphere 286 RLT
2009 Silverado 2500HD
litgrep is offline   Reply With Quote
fan
