Old 02-06-2014, 12:46 AM   #1
Fantastic fan
I will be adding fantastic fan in kitchen area of coachman concord 2013, they come in off white and polar. What is the best color to go with for the inside panels. Thanks in advance
larryhobby is offline   Reply With Quote
Old 02-06-2014, 07:45 AM   #2
TURBS's Avatar
White ceiling? Then polar.
TURBS
oc's buddy
Old 02-06-2014, 07:49 AM   #3
Thanks very much wasn 't sure but ceiling is white so polar it is. Thanks again
Old 02-09-2014, 03:48 PM   #4
fantastic fan
I am also thinking of adding fan, but to the bedroom on my 2013 concord 300TS,
let me know how yours turns out.
Thanks, riche
riche is offline   Reply With Quote
Old 02-09-2014, 04:04 PM   #5
TURBS's Avatar
Thanks, riche
I added one to my bedroom.
Pretty straightforward and didn't take but a few hours.
TURBS
oc's buddy
ID:	46019   Click image for larger version
Old 02-09-2014, 07:16 PM   #6
where did you get elec. power?
Old 02-09-2014, 08:11 PM   #7
TURBS's Avatar
I had a ceiling light about 8" from the vent I pulled power from there.
Fyi a heat gun and a plastic putty knife works well for removing the dicor sealant.
I used one complete tube to reseal the power vent but I'd get two just in case.
TURBS
oc's buddy
Old 02-09-2014, 08:24 PM   #8
Ford Idaho's Avatar
TURBS
oc's buddy
What did you use between the fan housing and the roof?
Old 02-09-2014, 08:31 PM   #9
TURBS's Avatar
I used a very fine line of self leveling dicor before I set upper housing in place as that's what ias under ther the original vent.
TURBS
oc's buddy
Old 02-09-2014, 08:40 PM   #10
Ford Idaho's Avatar
TURBS
oc's buddy
Would that work better than butyl caulk?
I have a big roll of it from another job I did.
Old 02-09-2014, 08:45 PM   #11
TURBS's Avatar
Scratch that......
It did have a strip of butyl tape.
For some reason I was thinking I used dicor around the perimeter.
I apologise.
TURBS
oc's buddy
Old 02-09-2014, 09:03 PM   #12
Ford Idaho's Avatar
Scratch that......
I apologise.
TURBS
oc's buddy
No need to apologize.
I plan on installing a Maxxair (weather permitting) this spring before our first trip, just trying to get a ton of info before hand, thanks for the input.
Old 02-09-2014, 09:30 PM   #13
TURBS's Avatar
No problem.
I have to get my max air installed back on since I changed the vent.
TURBS
oc's buddy
fan
