Old 04-05-2015, 07:15 PM   #1
Freelander not level when sitting on a level spot
I'm curious why my Freelander's front end is lower than the backend. (No slide out.)
It would seem to me that the interior floor should be level when parked on a level spot. It is loaded with water and supplies.
All the tires are new and the same size, actually the same tires that came on the unit from the factory in 2007.
So I assume this is normal, but why?
2007 Chevy Couchman Freeloader
klspahr is offline   Reply With Quote
Old 04-11-2015, 06:56 AM   #2
tmhyer's Avatar
The back end is higher to accommodate the weight of the water tanks and for towing, just like on a pick up truck.
tmhyer is offline   Reply With Quote
Old 04-11-2015, 07:26 AM   #3
Carknocker Family
Ida Ratherbe Camping's Avatar
Are you saying that the tires are 8 years old?
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 04-11-2015, 07:38 AM   #4
Originally Posted by klspahr View Post
...All the tires are new and the same size, actually the same tires that came on the unit from the factory in 2007...
Don't think that's what he is saying. I understand it they are the same size as came on it EXCEPT new.
Old 04-13-2015, 08:11 PM   #5
Thanks tmhyer, i don't tow so that never occurred to me...
Old 08-12-2015, 08:56 PM   #6
Any thoughts on having lowering shackles installed to make the vehicle sit level?
I'm getting tired of have to level the vehicle when I'm parking on level ground. I have no plans to ever tow a vehicle behind this motorhome.
Old 08-13-2015, 03:23 AM   #7
If you lower the rear end enough to level the coach you will reduce the rear end's ground clearance a lot.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 08-13-2015, 09:40 AM   #8
Former Full Timer
Duckogram's Avatar
Lowering the chassis by raising the rear suspension can cause major problems including reducing your departure angle to the point that you may hit bottom going up a driveway.
Possible solutions:
Class C (Chevy) EZ Wireless System
https://lci1.com/level-up-motorhome-leveling-systems
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 08-14-2015, 06:27 AM   #9
Roll's Avatar
I had the same reaction.
Gary
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 08-14-2015, 06:31 AM   #10
Roll's Avatar
The leveling jacks are easy to use and don't just level the rig, they provide stability as you move around inside.
Are the jacks just too much trouble?
Gary
