10-27-2016, 10:51 PM
Fresh Water refill
I have a 21ft Coachman QB. This is the first RV I've ever had where I can't find or figure out how to fill my freshwater tank which is now empty.
How/Where do you fill the fresh water tank?
10-28-2016, 04:46 AM
World Wide Wanderer
Where does you fresh city water hose hook up? Is there a small blue lever by where the hose hooks up? If it is similar to my Concord, you hook up your water hose and flip the lever to "Tank Fill", then flip it back to use city water pressure.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
10-28-2016, 08:10 AM
I will check that out as soon as it stops pouring rain. There isn't a separate hose connection for the fresh water so that would make sense.
10-28-2016, 05:41 PM
I can't find a valve to fill the fresh water. Tech Support at Coachman couldn't help me.
10-28-2016, 05:57 PM
What year is your coach? Back a few years they used a gravity fill port a hose could be inserted into. Came with a screwed cap. My 2003 Coachman Santara had a multiple valve manifold.
10-28-2016, 06:02 PM
2016.i have one connection for city water, the other to clean the black tank. There is no other place to connect a hose.
10-28-2016, 06:15 PM
Look for a round plastic cap about 1 1/2 inches in diameter. Mine is on the back of the trailer, but it could be anywhere. Take off the cap, put the hose in the tube and fill your tank.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
10-28-2016, 06:37 PM
Gotta believe somewhere near the city water is an unmarked 3 way valve lever. Turned 90* it will cause the city pressure to fill the tank instead. If left out can be retrofitted somewhat easily.
10-28-2016, 07:10 PM
World Wide Wanderer
Post a picture of your water fill area?
I am interested to see what you have. I would think it would be similar to mine. I will get a picture of mine. When you open the cover I have the fresh water hookup and the black tank flush, then there is a blue peanut shaped lever that you switch for fresh water/winterize or tank fill.
Aaron
Aaron & Rhonda
10-28-2016, 07:12 PM
Call your RV dealer when you made your purchase. They should have covered that during the Pre Delivery Inspection.
John
2014 Dynamax Trilogy 3850RL - South Hampton Interior, Full Body Paint (Black / Silver / White), MOR/ryde Independent Suspension, MOR/ryde Disc Brakes, ONAN 5500 Generator, Progressive Industries HW50C w/Dual Display, Winegard HD Dish w/DirecTV, Washer & Dryer, iSprings 7-stage Reverse Osmosis Water Filter, Trail-Air Flex Air Pin Box, Third AC installed, AC Voltage/Amp Meters, DC Amp Meter, Garnett See Level Tank Sensors, TST 507 TPMS
Retired USAF - Full Timers!
10-28-2016, 08:05 PM
John
x2!
10-28-2016, 08:52 PM
Will do tomorrow in daylight
10-28-2016, 08:54 PM
Called the dealership. They will get back to me. My dealer wanted $1,000 to show me all the features. I passed
10-28-2016, 09:51 PM
Omg tell us what dealer that is so potential customers can avoid them.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
Coachman freelander
10-28-2016, 10:02 PM
I looked up your rig and it shows two black screw in water hose inlets on drivers side near rear of unit, they are right next to each other. The one on the left side is your city water inlet. The one on the right is your potable water fill. There is no indication your unit has a black tank flush.
2011 Jeep JK Toad
10-28-2016, 10:06 PM
I found the valve! It's under the kitchen sink. It's not even marked.
10-28-2016, 10:48 PM
Didn't find it
I think one of these values will fill my freshwater. I tried all of them but none seem to do the job
10-28-2016, 11:03 PM
I would think those are the valves for your fresh water, cold water and hot water low point drains
2011 Jeep JK Toad
10-28-2016, 11:45 PM
Yep, those are your low point drains, not the FW fill.
