Old 04-08-2016, 05:15 PM   #1
ezflyer's Avatar
Fresh water tank
After arriving home too early from AZ, I am trying to winterize my 2014 Mirada. I put 7 gal. Of anti-freeze, should be plenty, but the pump won't pick it up, decided to drain the tank and start over but the tank will not drain either. Took the line off the pump should get fluid but none comes out, I am thinking there is an obstruction in the tank or the vent line is clogged where ever that is.I have tried compressed air to no avail, any ideas?
ezflyer is online now   Reply With Quote
Old 04-08-2016, 05:23 PM   #2
MNtraveler's Avatar
Have you tried compressed air going the reverse direction, up through the drain line? Otherwise a small metal rod or snake up through the drain line might do the trick.
Anyway, you aren't putting the antifreeze in the FW tank, are you? You should be able to pull it in with your pump (using the winterize line/valve if it's there -otherwise it can be added) and pump directly from the antifreeze container into the hot and cold water lines. Don't forget to drain the hot water tank first and put it on bypass so you don't fill it with antifreeze too.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 04-08-2016, 05:44 PM   #3
ezflyer's Avatar
Already tried compressed air and a coat hanger, can't get all the way to the tank because of tee's and els. Yes I put the anti- freeze in the FW tank, no room to install the winterizing kit, I did it this way last year with no problems.
Old 04-09-2016, 02:13 PM   #4
Hugh R's Avatar
Anti-freeze in the FW tank?, really? Why not just drain it and the lines?
2013 Mirada 29SE, I earned it!
Hugh R is offline   Reply With Quote
Old 04-09-2016, 03:37 PM   #5
MNtraveler's Avatar
See post #3.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
Old 04-09-2016, 10:30 PM   #6
Hugh R's Avatar
Isn't it Summer there, why not work out the problem first. Anti-freeze is toxic. Unless you poured in some drinkable stuff.
Old 04-09-2016, 10:53 PM   #7
What is "Drinkable Stuff"? Youroo!!
Old 04-09-2016, 10:59 PM   #8
caper's Avatar
RV antifreeze will not kill you. You could drink it but I would not.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-09-2016, 11:04 PM   #9
I have never seen it listed on a Menu or drink list at Bars! Youroo!!
Old 04-09-2016, 11:50 PM   #10
I wouldn't be surprised if a group of kids were mixing it with Red Bull and serving it at a frat party.
tkarper14 is offline   Reply With Quote
fresh water, tank, water, water tank
