Old 09-08-2015, 01:35 PM   #1
Fresh Water Tank Drain
Noticed my fresh water tank has slight odor when faucets turned on after short storage. I want to drain the tank and clean out with bleach. I have read plenty of instructions on how to accomplish this. My only question is how do I identify to proper line to drain. In my Mirada, I have two white tubes and one red tube with small valves. I assume the red one is the water heater, how do I know which line is used to drain the fresh water tank?
Bob & Sue Rowan
Okeechobee, FL
2012 Coachmen Mirada 29DS (SOLD)
2015 Keystone Bullet Travel Trailer
2016 F-150 Lariat with Auto Trailer Backup
Dog = Morki (Yorkie-Maltese) - Zoe
Malabarbob is offline   Reply With Quote
Old 09-08-2015, 01:46 PM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
Should be one white valve close to the bottom of the fresh water tank and should be a label on the side of tt indicting location of drain. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 09-09-2015, 01:20 PM   #3
Hugh R's Avatar
I'd do the bleach:water thing 1:10 ratio, and run the water pump and flush the faucets, shower, toilet, everything and then open up all three valves, and then refill and flush again.
Hugh R is offline   Reply With Quote
Old 09-09-2015, 01:29 PM   #4
Ford Idaho's Avatar
Run the bleach water mix thru every line even the low point drains, outside shower, all of them.
Old 09-09-2015, 01:42 PM   #5
Ratio of bleach to water is closer to 1:1000 - 1/4 cup per 15 gallons of fresh tank capacity.
WY Husker Fan is offline   Reply With Quote
Old 09-10-2015, 12:34 PM   #6
Chuck.C's Avatar
Don't forget the water filter. I removed the element and closed up the empty case, so it would get the bleach treatment. The filter was nasty and had the same smell, so it was replaced with a new one after the rinse.
2013 Coachmen Mirada 35DL
Chuck, Susan, and dogs- Gracie the Registered SnackHound and Toby the Wonder Boxer
Chuck.C is offline   Reply With Quote
Old 09-10-2015, 04:14 PM   #7
Hugh R's Avatar
You are correct Sir. My typo error. 80 gallon tank= about 1-1/2 cups of bleach. 8 gallons of bleach in an 80 gallon fresh water tank, would not be good!
Old 09-11-2015, 09:31 AM   #8
Wolverine 1945's Avatar
There is chemical we can add to our fresh water,,, that is suppose to keep it fresh longer,,, I think it is Called Fresh Water ???
Wolverine 1945 is offline   Reply With Quote
drain, fresh water, tank, water, water tank
