Old 09-16-2014, 10:18 AM   #1
meg
Front end clunking sound
After going on some very rough roads this summer our 2011 Coachman Mirada developed a clunking noise in the right front end. We had a mechanic look at it at Yellowstone and he said he thought it was in the chassis and Coachman would have to look at it. We really hear it when we are driving slow like through a campground or parking lot. In fact the whole motorhome sounds like it is coming apart. Has anyone put heavier shocks on to give it a smoother ride?
meg is offline   Reply With Quote
Old 09-17-2014, 07:36 PM   #2
Roll's Avatar
Torque your anti-sway bar link ends and the brackets that hold the bar to the axel or frame as the case may be.
I think stock torque is 60 ft lbs but check with your dealer to be certain.
Gary
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 09-17-2014, 09:04 PM   #3
Anacortesians
We've had a similar noise on our rig ('02 F-53 chassis). I'm pretty sure its a sway-bar bushing that's worn to a point where there's clearance, but haven't gone after it (yet?).
Frank and Eileen
No longer RVers or FR owners
Old 09-17-2014, 09:07 PM   #4
Done with this
Yep. I'd say a bushing somewhere has gone bad. Maybe the end links, sway bar or the shock bushing. Should be easy to find.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 09-17-2014, 09:28 PM   #5
Wa11y757's Avatar
X2 on sway links.
Wa11y757 is offline   Reply With Quote
Old 09-18-2014, 04:30 AM   #6
Former Full Timer
Duckogram's Avatar
I read the OP a number of times trying to figure out what the issue was. All I can say is that most folks replace the OEM Bilstein shocks with Koni's. I don't know that they are "heavier" or not.
As a side note (not that you asked) related to the clunking noise, x4 on the greatest possibility that it is a bushing/mount related issue however taking it to Coachmen is what I consider bad advice. You have a Ford F-53 Chassis. You would, IMHO, be best served by taking it to a certified Ford truck mechanic if you do not have the ability, knowledge or desire to DIY.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
