Old 08-01-2015, 09:19 PM   #1
Front end noise
Hi, I just purchased a used 2012 Mirada 34BH. It has the Lippert leveling jacks. When I turn the ignition key to the accessory setting I hear a grinding noise almost like something is running. Is this the leveling system or something else? Is this normal?
prairiegopher is offline   Reply With Quote
Old 08-01-2015, 09:30 PM   #2
Check the dash blower fan first. Normally have to turn the levelers on manually.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 08-02-2015, 12:41 PM   #3
Thanks for the reply. I found that even with the key off and I step on the brake, the noise starts. It sounds like a motor right by the brake. The tech said it is the brake pedal thinking it is an adjustable pedal?? Can someone with a newer coachmen give this a try to confirm this. I'm not sure if I should believe this or not??
Old 08-02-2015, 01:03 PM   #4
Tim & Lisa Trempert
It is the boost system for the brake.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 08-02-2015, 02:57 PM   #5
Roll's Avatar
Yup, that man is correct. Its common on the Ford chassis and nothing to worry about.
Gary
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 08-02-2015, 05:05 PM   #6
Thanks Guys,
Now I can get some sleep, lol!!!!!
