Gap between inside wall and the slide flange
I have a 2012 Coachmen Mirada 32DS. When the slides are fully extended,
I noticed that there is a 3/4 inch gap between the inside wall and the flange
of the slide. Is this pretty normal in a motor home? On my fifth wheel RV,
there is no gap between the wall and the slide flange.
I feel that outside cold air can go thru the gap even with the rubber moulding.
I will measure the inside and outside temp using a digital infrared
thermometer thru the rubber moulding.
Please chime in.
