Originally Posted by BlackJeep22
Aaron,
Is there a way to do this to JUST the generator, or do you have to add it to the main gas tank?
You can mix up a gas can full, pull the fuel line where it leave the generator and goes to the main gas tank, then pull from the gas can. Might need to get an extra piece of line. I have done that in the past when trouble shooting on an RV. I actually had a 2 gallon metal gas can with a petcock and hose fitting on it. I would set it up on a table for gravity feed.
Aaron
