03-19-2016, 08:59 PM
Great. Refer now not working
Sitting in the driveway getting ready to head out for the weekend, the freaking refer stop working, it will not cool. So back to the shop next week. I is starting to P me OFF........
Art & Rhonda
Greenwood, In.
2016 Concord 300 DS
03-19-2016, 09:01 PM
How long has the fridge been on?
Rv type or residential?
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
03-19-2016, 09:08 PM
Its been on a week. Work great last weekend came home on Monday and was going o leave this morning. NOPE it is a RV type. Its in a new Concord, gas and electric. was in the electric mode sitting in my driveway plug in. When I realize that it was not working I switch to gas NOPE nothing.
Art & Rhonda
Greenwood, In.
2016 Concord 300 DS
03-19-2016, 09:10 PM
is the RV level in your driveway? How long did you wait after switching to propane to see if it's working?
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
03-19-2016, 09:17 PM
Was anything in it?
Was the freezer cold?
2008 2500hd Duramax
2015 Columbus 320RS
03-19-2016, 09:21 PM
Drive way not level but not crazy step, I let it run on gas for like 2 hours while my wife and I went to dinner. Still no cooling. Park our older unit here before without a issue. Does they have to be flat level?
A few things in it, not a lot. I could not put anything in it temp is in the 60. Freezer same temp as the box
[IMG] [/IMG]
Art & Rhonda
Greenwood, In.
2016 Concord 300 DS
03-19-2016, 09:24 PM
Is it cold where your at in Indiana?
2008 2500hd Duramax
2015 Columbus 320RS
03-19-2016, 09:27 PM
Turbs yes it only got into the 40's today. I was thinking not enough temp Delta to let things work. Kind of like a A/C unit never run it when below 60. But I ran my TC refer in Montana when temps butt cold. Still keep things cold. Freezer kept game frozen no issue.
Art & Rhonda
Greenwood, In.
2016 Concord 300 DS
03-19-2016, 09:33 PM
I think it's a temp issue honestly,
Fridge requires heat to work.
At best the fridge runs 34 degrees or so. If outside temp is near freezing it likely won't turn on.
I assume your running the heat in the camper to be 60 degrees?
2008 2500hd Duramax
2015 Columbus 320RS
03-19-2016, 09:38 PM
Yes we have the heat pump on, wife was working in it today. It got into the 40's today. Also if I put anything in it would not keep cool. The butter even started to turn liquid. And the freezer was the same temp as box, anything in there would for sure thawed out.
Art & Rhonda
Greenwood, In.
2016 Concord 300 DS
03-19-2016, 09:53 PM
Are the coils hot in the back?
2008 2500hd Duramax
2015 Columbus 320RS
03-19-2016, 10:08 PM
That I dont know, are they suppose to be? I can check it tomorrow. I shut it down for now. But I can check tomorrow. What to look for?
Art & Rhonda
Greenwood, In.
2016 Concord 300 DS
03-19-2016, 10:09 PM
Remove outer cover and turn fridge on.
Coils will get hot or should.
Does fridge light come on?
2008 2500hd Duramax
2015 Columbus 320RS
03-19-2016, 10:19 PM
Yes light does come on and also I can hear it trying to come on. I might add this past weekend when in electric mode I could here a nose coming from the bottom of the unit.
Art & Rhonda
Greenwood, In.
2016 Concord 300 DS
03-19-2016, 10:23 PM
turbs....... PM sent
Art & Rhonda
Greenwood, In.
2016 Concord 300 DS
03-20-2016, 05:01 AM
most older rv ref. I have worked on require 12 volts DC to run the control board regardless of gas or 120 AC volt operation.Check whether 1. you had the battery disconnected thru the disconnect switch or you have a blown 12 volt fuse. As new as your unit is it may be different in some way but it has to have current to fire the propane.
03-20-2016, 11:23 AM
After talking with the op last we discovered that his thermistor had fallen out of the slider.
Hopefully that fixed the problem.
2008 2500hd Duramax
2015 Columbus 320RS
03-20-2016, 01:21 PM
Make sure the burner is lit. Mine takes 3 tries before it will stay lit because of air in line. Light a burner on the stove. It helps purge air from line.
03-20-2016, 03:37 PM
See post #17.
03-21-2016, 09:42 AM
Kanadian Kamper
Rescue Duct
Right after we took delivery of our rig, the first time out, our fridge did not work either. First time jitters? Were we doing something wrong?
Long story short........after sitting at dealership waiting for warranty repairs (fridge among others) the fridge worked without them doing anything. Turns out, it was because our driveway was on too much of a slope, and the fridge became adapted to a NEW level. Turns out the slope of our driveway was too much............in review, certainly we would NOT have camped at that slope.
Can't tell for sure from your picture in your driveway, but would you actually camp in your RV at the slope of the driveway?
Try making sure you're really level and turn on the stove to get the propane flowing properly towards the fridge. It may take some time (days)after being really level to prove the solution.
Good Luck.
Ken and Terry
