Old 07-01-2014, 11:54 AM   #1
Heat/AC Thermostat Change
I want to change my analog thermostat to a HUNTER #4299B Digital therm. I have a Atwood MPD 33179 furnace and a Duo- Therm 59516531 roof air. The existing therm. is a Duo-Therm 4 button unit #3107541 with 7 wires, and the Hunter only has 5 wires. Both systems are ducted. I also want to have both high & low speed for the AC. I have found wiring for a Suburban furnace to HUNTER, but nothing on Atwood. Ant one have a wiring drawing ????????????
Clyde, Patty, & Lugnut the Dog
2004 Coachmen class C Santara 309KS
k1ngdlm is offline   Reply With Quote
Old 07-01-2014, 04:17 PM   #2
Found Infomation
I found the wiring diagram I was looking for. I have made the change over and it works great. Used Radio Shack #275-324 SPST mini toggle switch for fan high speed setting. Took about 1 1/2 hrs. to finish. Temp. inside motor home was 97 F when I finished.
thermostat
