Old 10-16-2019, 11:43 AM   #1
Carl17's Avatar
Help auto leveL leak
My equalizer system is leaking oil at motor,dripping off end.
(see picture ) I think it only leaks when running pump motor. Any one else have this problem ,cant find any info on seals or parts break down. Out of warranty an 12 hours from dealer. rest of pump assy is clean .just dripping off end of motor,has not rely using any oil .
ID:	217401   Click image for larger version
Carl & Bette
2018 Leprechaun
NEW YORK
Carl17 is offline   Reply With Quote
Old 10-17-2019, 12:45 PM   #2
Carl17's Avatar
drip
clean up ran than drip
Carl & Bette
2018 Leprechaun
NEW YORK
Old 10-21-2019, 05:50 AM   #3
Witch Doctor's Avatar
I never seen that problem before, but I would think that there is a “O” ring under the cap, also it looks like 2 bolts if I’m seeing it correctly, did you try and tighten the bolts? I’m just guessing here, what system is that on? Did you call the company , maybe they can shed some light on it. Good luck
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-21-2019, 05:52 AM   #4
Oh just seen what system it is, also seen a 800 # printed on it. Give them a call
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-22-2019, 10:48 AM   #5
Carl17's Avatar
Unhappy Equalizer
Call them to find out the hole pump, motor has to be replaced. Seal is not service able.. going to keep and eye on it for a while and my take it apart when we get back in spring ..
Carl & Bette
2018 Leprechaun
NEW YORK
Old 10-29-2019, 08:16 AM   #6
Carl17's Avatar
fix
Thanks to Jason Johnson, Coachman and Randy Bowling, Equalizer . Had replace pump /motor assy. Was a lot wrost than I thought .
Carl & Bette
2018 Leprechaun
NEW YORK
Old 10-31-2019, 08:05 AM   #7
Carl17's Avatar
leaking
The leak was wrost than i thought. But a piece of cake to change pump asssy.
Carl & Bette
2018 Leprechaun
NEW YORK
leak
