Old 05-03-2015, 11:01 AM   #11
Former Full Timer
Duckogram's Avatar
Originally Posted by jjd74 View Post
Here's a pic of theAttachment 75987 over flow pipe
Is that daylight I see at the floor?
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 05-03-2015, 11:09 AM   #12
jjd74's Avatar
Aye.
jjd74 is offline   Reply With Quote
Old 05-03-2015, 11:17 AM   #13
jjd74's Avatar
Aye.
Oops. Meant more. I was intrigued to find the drain line (still don't see it) after seeing that daylight too. This is a live action sequence of attachments: First is general area of drain outlet location before overfill, second shows some water coming out around pipe. I heard the gurgle and whoosh, it's basically under the sewer bumper alongside the frame. Seems a fine spot.
Old 05-03-2015, 11:18 AM   #14
jjd74's Avatar
oops. Meant more. I was intrigued to find the drain line (still don't see it) after seeing that daylight too. This is a live action sequence of attachments: First is general area of drain outlet location before overfill, second shows some water coming out around pipe. I heard the gurgle and whoosh, it's basically under the sewer bumper alongside the frame. Seems a fine spot.
Name:	ImageUploadedByForest River Forums1430669898.123573.jpg
ID:	75990Click image for larger version
Name:	ImageUploadedByForest River Forums1430669910.824170.jpg
Old 05-03-2015, 09:06 PM   #15
jjd74's Avatar
Update: I do see the pipes, I realize now as Ducky noted several posts ago, you can see them poking out across from the rear compartment if you're looking up into the chassis frame. Mystery solved.
bypass, cat, hot water, location, water
