Old 10-01-2015, 10:59 PM   #1
Hugh R's Avatar
Hydraulic Oil for Leveling System
Mine is low, what do you put in the reservoir?
2013 Mirada 29SE, I earned it!
Hugh R is offline   Reply With Quote
Old 10-01-2015, 11:01 PM   #2
Certified Curmudgeon
Assuming it is a level-up, it takes transmission fluid. I suggest using Mobil1 full synthetic.
Mike Dropped
Old 10-01-2015, 11:21 PM   #3
Hugh R's Avatar
Really, just ATF, nice. Yeah, I only use Mobil 1 in my Honda generator. Thanks, I'll buy some Mobil 1 ATF tomorrow.
Old 10-28-2015, 03:26 AM   #4
pashooter's Avatar
Late to this party, I know, but am just now in the process of collecting manuals and tech data for all the systems in my new Pursuit. If you're interested, go here for an LCI manual:
http://www.lci1.com/assets/content/s...d-leveling.pdf
And yes, it takes what they call "Type A" ATF: the manual states either Dexron III or Mercon 5; so as long as your Mobil 1 meets (or exceeds) those specs you should be fine. Also take note: only top off the reservoir with the jacks up, otherwise it will overflow when you retract them.
2016 Coachmen Pursuit 31BD
2015 Jeep Wrangler Sport Toad
Nights camped in 2019: 76
pashooter is offline   Reply With Quote
hydraulic, leveling
