Old 04-21-2013, 05:27 PM   #1
Roll's Avatar
Interesting discovery while under coach
How would you know about these things unless you crawl under your coach from time to time.
In the first pic I noticed that the gas filler tube was up against a piece of angle iron. It would eventually wear through the gas filler tube leaking gasoline in the least and creating a fire hazard at worst. I cut a piece of rubber 1 1/2 tubing and clamped it to the filler tube to prevent damage, (pic 2 and 3).
In the fourth pic I noticed that a piece of limestone gravel (white looking rock) had wedged between the gas tank and the frame. That would eventually (chemical reaction) eat through the tank, same problems as above. Had difficulty getting it out, but out I got it.
Roll
ID:	28598   Click image for larger version
ID:	28599   Click image for larger version
ID:	28600   Click image for larger version
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 04-21-2013, 06:02 PM   #2
statgeek's Avatar
What model Coahmen do u have? I'm wondering if mine is likely to suffer the same flaw??
2013 Fleetwood Discovery 40G
BlueOx Aventa & Patriot Braking System
2009 Jeep Wrangler Unlimited
statgeek is offline   Reply With Quote
Old 04-21-2013, 06:18 PM   #3
Lynkage's Avatar
Good catch Roll!!
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 04-21-2013, 06:32 PM   #4
Roll's Avatar
2011 Encounter Ford Chassis. Follow the gas filler tube from the rear, up the drivers side where it turns and goes into the tank. The angle iron was on the back of a compartment and closer to the tank than the cap at the rear.
Old 04-21-2013, 08:00 PM   #5
1nshort's Avatar
Roll,
Great catch. I am going under my '13 to see if they corrected that one. Also noticed all that shiny metal under my Encounter and thinking about Rustoleum priming and flat black top coating before it starts deteriorating.
2013 Encounter 37TZ, Chalet Pkg, Escape Hybrid Toad,
Denis & Gail & Dixie the Blue Merle Sheltie
1nshort is offline   Reply With Quote
Old 04-22-2013, 06:58 AM   #6
go6car's Avatar
GEEZ!! My better half was under the coach last weekend and was neatening up some cables, etc. I will have him check as well.
We have an early production 2013, so the chassis is 2012. (1nshort - did you see anything on yours?)
2013 Coachmen Encounter 36KS
(Forest River adopted cousin! )
2004 Jeep Wrangler
go6car is offline   Reply With Quote
Old 04-25-2013, 07:11 PM   #7
1nshort's Avatar
Roll & go6car,
Went under coach today to check out the gas filler tube run. Looks like they fixed it in the 2013. From the back of the coach at the filler door all the way to where the filler tube and vent line enter the tank, there is about 2 1/2 fingers space on each side there are also two stabilizer clamps 1/3 and 2/3 of the way down that hold the pipes in place. Where the tube and vent bend 90 degrees to enter the tank there is an angle bracket but the pipes have neopreme tubing clamped to them using screw secured hose clamps. Also the angle bracket edges are rounded so there are no sharp edges. The neopreme is about 3/8 of an inch thick.
Old 04-25-2013, 09:55 PM   #8
go6car's Avatar
We took a look today too just to make sure. Here are some pictures. Glad to have had the heads up just in case!
2004 Jeep Wrangler
Old 04-26-2013, 06:50 AM   #9
Roll's Avatar
I see the difference right away. My filler tube runs from the cap directly to the elbow that goes into the tank. Yours is cut short and the length of neoprene is used to make the adjustment to line up with the elbow, (I don't have the neoprene section).
I'll keep this in mind. If I see my fix isn't working, I'll wait for a nice day when the tank is low and remove the long filler tube, cut it off and insert a section of neoprene. Cost would be minimal. I have some brackets too but I would have to realign them to pull the filler tube farther away from the sharp edges.
This should probably have been a recall item for Coachmen but I'm glad I caught it.
Roll
Old 04-26-2013, 06:53 AM   #10
Roll's Avatar
By the way.... you folks and your unused coaches.....
All that clean, new looking, underside will disappear you know, after a few miles and a couple of seasons.
