Old 08-21-2014, 01:05 PM   #1
Led light
I was going to change my lights in 2013 Coachman Concord to Leds. I wanted to know which LEDs are being used in new coaches whether it is the warm white, cool white or natural light. Thanks in advance
larryhobby is offline   Reply With Quote
Old 08-19-2015, 07:28 AM   #2
Cool white. You have to try and see how your interior color reacts with cool white or warm.also you have to find the lumen out put is . output is the most inportant thing.
old rv man is offline   Reply With Quote
Old 08-19-2015, 08:46 AM   #3
7 Year Class A RV'er
Just a heads up for when you do install the LED's. Depending on the type of bulb that you already have, the positive and negative terminals may be interchangeable (i.e., you can put the bulb in either way). With LED's, there is always a positive and a negative. If the bulb doesn't light when installed, simply turn it around. Also, best place I found for replacement bulbs is Amazon.com.
2015 Legacy SR340 360RB
Old 08-19-2015, 09:15 AM   #4
When I switched over to LED units in our Pursuit I purchased most of them on E-bay. Picked up some warm white and bright white. Found the warm white to be good over the bed and bright white in the kitchen area and were the wife works on her crafts, or reads a book.
Current draw is so little that the fan on the converter never kicks in, when all the lights are on.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is online now   Reply With Quote
Old 08-19-2015, 09:36 AM   #5
GreenImp's Avatar
Send a message via MSN to GreenImp
This is not correct. It is only true of the cheaper/older LED bulbs. The "better" LED bulbs have a small additional circuit that allows them to be installed either way. These bulbs are usually listed as "AC/DC". These AC/DC bulbs also usually have voltage regulation built in and will be listed as working on a wider voltage range (eg. "10v to 20v" vs "12v only").
Prices for LED bulbs for the home are plummeting. It will be nice to see that happen with the automotive ones too.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 08-19-2015, 09:45 AM   #6
Flybob's Avatar
Most all LED modules use a high freq drive circuit to drive the chips. Some of the very inexpensive Chinese units use very RF noisy drive circuits that when on will kill your TV and Radio reception. If you are planning on ordering a number or LED modules, I recommend using ones that have been used by forum members with success or buying one or two and trying them before ordering 20. Also after installing a module, check the temp after it has been on for a while. The cheap driver circuits can overheat and damage the fixture.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
led, light
