Old 01-04-2016, 09:25 AM   #1
LED Light Strip
I have a 2012 29DS Coachmen Mirada and would like to add one of those exterior multi-color LED strips in the RV just under where the awning rolls up. Is this a do-it-yourself project? I am good with wiring. Are they usually 12 volts? Where best to pick up the power?
Bob & Sue Rowan
Okeechobee, FL
2012 Coachmen Mirada 29DS (SOLD)
2015 Keystone Bullet Travel Trailer
2016 F-150 Lariat with Auto Trailer Backup
Dog = Morki (Yorkie-Maltese) - Zoe
Malabarbob is offline   Reply With Quote
Old 01-05-2016, 08:58 AM   #2
Former Full Timer
Duckogram's Avatar
Hope this helps: 2013 CC 36RE - how to get cable inside for LED lights
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 01-05-2016, 10:24 AM   #3
Left Coast
It is a do-it-yourself job. Have you found out where your awning motor wires are in relation to awning arms?
Old 01-05-2016, 10:49 AM   #4
DougP47's Avatar
I mounted mine under the awning side wall. I got my power from the porch light ( I didn't like the yellow light). Use the light switch to operate them. That way if the awning is closed up I can still use the lights. I bought a package of cable way and ran the wire inside it. been there for 3 years no problems.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 01-05-2016, 10:55 AM   #5
Left Coast
If you do a search, you'll find a RF controller where you can mount anywhere and push a button to do it all...mine is in storage area and no problem sitt'n inside to activate any light function....have light strips on bottom side of awning rail on trailer and in roller, and steps
Old 01-05-2016, 11:09 AM   #6
Flybob's Avatar
My experience is that many of the LED strip manufacturers do not use the highest quality mounting tape. Since the LED strip is exposed to weather continually, I augmented the tape with 3M automotive trim tape. You do not have to remove the supplied mounting tape, just the protective strip. Never had one come off. It is available on line or any auto parts store.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-05-2016, 08:36 PM   #7
I mounted the strip up under the awning track, and ran the wiring in next to the power awning wires. Ran the wires down the frt post and along the frame to the battery compartment. Installed the wireless controller near the step well breakers.
ID:	97325   Click image for larger version
ID:	97326   Click image for larger version
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
led, light
