03-08-2017, 08:09 PM
LEDs for RV's now are cheap(er)
I bought my Class A RV four years ago. Then, LED lights for the interior were about $10/each, no thanks. I just ordered 20 from Amazon for $20, a buck each. They suck about 1 watt where the older incandescent ones sucked about 20 watts each. Spade connector, direct replacement, "warm" lighting. Nice when you're "dry camping" with no shore power, and don't need/want to run the generator as much.
Also, the old filament bulbs tend to break with all the vibration traveling down the road. Just thought I'd share.
I bought these. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2013 Mirada 29SE, I earned it!
03-12-2017, 11:23 PM
LEDs
Left is a regular bulb at 20 watts, right is an LED at 1 watt. Same in the RV, left is regular, right is LED, a tad bit brighter, but I can live with it. The regular bulb was too hot to handle with finger tips at 30 seconds, the LED was cool after 1/2 hour. At a buck each, for the LEDs, I'm happy. Plug right in.
03-13-2017, 12:04 AM
Cheap LED's are usually that cheap and not long lasting. I only buy CREE Led's. CREE's average 35,000 hours.per lamp or longer than you'll be around.
Why spend 30 or 40 grand for an RV and then install cheap LED's I only want to replace them once.
03-13-2017, 05:39 AM
I just ordered LED G3s to replace the halogens. Got on a lightening deal on Amazon. $7.99 for 10 bulbs. Similar bulbs are $7.50 each at Lowe's. I got 20 LEDs 3 years ago from Amazon to replace the 921s and they are all still going.
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
03-13-2017, 05:53 AM
Who Dares, Wins
Similar price, probably same bulbs. Have been running them since 2013. I did have one loose one row of bulbs last season. I think I have 12 installed. Prior to this I had the expensive 12$ a bulb ones since 2009 or 10. Only two are still working. The rest burned out in 2013
2015 Chevy HD D-Max
2022 Impression 315MB
03-13-2017, 04:25 PM
20 out of 20 worked, seem to be polarity dependent, a few didn't some on, so I turned them 180 degrees and worked perfectly. Wifey may find them a little too white for the bathroom mirror (make up) area, in which case, I'll put back in the regular bulbs over the bathroom counter. I need four more, but I may pass given the little use of that area of the RV when I need light.
Plus I now have 20 regular bulbs for exterior replacement, I don't care much about the energy usage on outside bulbs when I'm driving.
The Amazon ad says their good for 50,000+ hours. I replaced all 20 in about 15 minutes.
03-13-2017, 04:27 PM
Have you tried the tv or FM radio with the lights on?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
03-13-2017, 04:35 PM
Who Dares, Wins
Yes, some of the cheaper leds make lots of noise so they can interfere or block weak signals, especially the TV.
I can say I have no TV issues, but I use a hardrive not over the air. I have never turned on the radio.
2015 Chevy HD D-Max
03-13-2017, 05:49 PM
Something that cheap, no shielded LED's are good for. CREE's never.
03-13-2017, 05:53 PM
I'm the polar opposite of you.
I want all my marker lights, turn signal bulbs and brake lamps to be LED because that allows me to seal up the lenses to keep moisture out (I still coat all the bulb bases with Di-electric grease) and not worry about replacement ever again.
been changing all the shop T8's to LED bulbs as the ballasts puke. Been using the single end 4 foot LED tubes and direct wiring them and landfilling the ballasts. Twice the light output, half the current used and no 60 cps flicker or cold start issues.
03-13-2017, 06:56 PM
I bought some just like those and only 3 are still working less than a year later. In fact many started flickering within the first few weeks.
2020 Grand Design Reflection 240 RL
2006 F350 Lariat Crew Cab Super Duty 6.0 diesel 4X4
03-13-2017, 06:59 PM
I guess I'll find out soon, taking it to the Grand Canyon is three weeks.
03-13-2017, 07:22 PM
? for SidecarFlip
I like your advice, do you have link for where to buy the CREE Led's?
2012 Rockwood Windjammer 3008 W
2020 Tundra Dbl Cab 4X4 SR5
04-09-2017, 03:44 PM
No TV noise from the LEDs.
04-09-2017, 03:46 PM
www.superbrightLEDs.com
04-09-2017, 03:54 PM
While on the subject of high tech alternatives, take a look at L-Iron storage batteries. a 100 amp hour battery weighs just 27 pounds, has an almost constant voltage output from full charge to no charge, can be totally discharged without harm and withstand hundreds of charge and discharge cycles without appreciable capacity loss
They are completely sealed (solid state) and can be mounted in any position and are impervious to low temperatures.
That are expensive compared to a conventional battery but in the grand scheme of lifetime are cheaper overall.
Just put 2 in my unit. 2 weigh less than one conventional battery and take up the same space as one conventional battery.
L-Iron batteries don't heat up, explode or catch fire like Lithium-Ion batteries can. and the recharge with a conventional RV converter.
