Old 08-09-2016, 09:43 PM   #1
levelling Concord..
It appears that the BIG FOOT levelers get a little over zealous when told to auto level. It always manages to get the front wheels off the ground..I even did a manual level and reset the device. Still jacks front wheels off the ground..So now I just manual level..Anyone else have the same situation..
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 08-09-2016, 09:47 PM   #2
Land of the Midnightsun
jjSpeedwagon's Avatar
Yes mine will do that I'll lower down using manual
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 08-10-2016, 05:51 AM   #3
World Wide Wanderer
wahoonc's Avatar
I have gotten in the habit of manual leveling. Not sure why it wants to jack the front wheels up so much. I think that the auto level is a great feature, just needs some tweaking to be perfect. I suspect there may be an issue with the sensors. Haven't taken the time to delve into it much. I am on the road 4-5 days a week 45-50 weeks a year so my play time is limited.
As long as they work most of the time in auto and always in manual I am good to go for the time being.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 08-10-2016, 08:35 AM   #4
Same with me. Every time I go auto Th e front gets too high. I just go manual and it works great.
richardelarson is offline   Reply With Quote
Old 08-10-2016, 10:49 PM   #5
GnS
For what it's worth, my Leprechaun does the same thing. Wants to have front wheels off the ground.
GnS is offline   Reply With Quote
Old 08-11-2016, 01:34 PM   #6
Shouldn't there be an adjustment to solve the AUTO problem? H asanyone called the Mfg. of the levelers?
Marvin
GA_Boy is offline   Reply With Quote
Old 08-11-2016, 02:43 PM   #7
There is a process to reset to level but for some reason it doesn't repeat after setting it. I've done it twice and still no good.
