Old 04-11-2014, 10:44 AM   #1
calebgold's Avatar
Looking for Banks Power experances wanted.
Has anyone had this installed in their Gas-er?
I'm trying to find out if it is worth the investment for the added power to the Ford v10.
I'm not trying to win races with my motorhome but I like to feel good when I'm going up the big inclines.
Any experiences would be appreciated.
11 Mirada 34BH
We travel with two loaded GSD!
San Diego, CA
calebgold is offline   Reply With Quote
Old 04-11-2014, 10:51 AM   #2
jevanb's Avatar
Had my SD 99 v10 banked years ago. Noticed a little bit extra power, but had to run premium fuel. And with a 42 gal tank it was expensive and thirsty
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 04-11-2014, 05:45 PM   #3
1nshort's Avatar
If you have the newer 30 valve v10 the gains are minimal. You would do better by getting the banks coolair injector mod, a engine tune like 5star tune (there are others) and changing out the muffler to reduce back-pressure. You will also be about 2000 dollars richer as opposed to the total Banks system.....however if you have the 20 valve v10 the gain is bigger, but still the above mods would (just in my opinion) do you better and leave you richer. I had the 20 valve v10 for almost ten years, traded up to an Encounter with 30 valve and have done the above mods (again). Did a lot of studying and debating and passed on the Banks system.
2013 Encounter 37TZ, Chalet Pkg, Escape Hybrid Toad,
Denis & Gail & Dixie the Blue Merle Sheltie
1nshort is offline   Reply With Quote
Old 04-12-2014, 07:36 PM   #4
Roll's Avatar
I thought the air restriction was minimal in the newer Triton engines. You did add a more open muffler and that helped?
I already have a tune but that's really only for the shift patterns but it does make a difference in all the downshifting.
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 04-12-2014, 07:39 PM   #5
Roll's Avatar
I already have a tune but that's really only for the shift patterns. However it does make a difference in reducing all the downshifting
Old 04-12-2014, 11:53 PM   #6
1nshort's Avatar
Roll,
Check out Brazel's website for the Ford Performance muffler. Do not know if the muffler adds any mpg (different brand but did make a difference on my 20 valve unit), but lower backpressure, lowering temps etc., always helps in the durability/survival end of things. Heat is a killer, shortens durability/life by aging things quicker. Couple hundred or so bucks much better than 2K plus (especially since gains in a 30 valve Banks is minimal for $ spent). Did notice with the cool-air injector replacing the stock inlet made a difference in shifts (pre-tune).
1n
power
