Old 06-30-2013, 09:12 AM   #1
Roll's Avatar
Make work project: reroute fresh water overflow
Applies to my 2011 37TZ; other models may have a different set up.
I got tired of bending down to look under the chassis in the area of the left side rear leaf spring to see when the fresh water tank was full. The overflow pipe hangs down right over the front of the rear leaf spring, and from there splatters all over everything. It is the water dripping from all over I watch for to be sure the tank is full.
Bad back, hard for me to bend over and nearly impossible for me to maintain bending over when watching for the water.
4 foot section of hot water 1/2" PVC and 4 elbows; $12 bucks more or less. made the fasteners from existing scrap parts.
So if I have these in the proper order:
1) Getting started, area of project.
2) end of stock overflow tube (1/2 inch hard rubberized material) just over the spring. Yellow arrow.
3) Fashioned 1/2 PVC pipe to divert around the spring and then run out to the side of the chassis. Felt tip pen to remember what ends go where.
4) Fastened completed pipe in place after wrapping it in metal tape. Tape is to get some modest heat reflection since the pipe is mounted about 6 inches from the engine tail pipe.
5) It works! Filled the tank and there it is, an easy to see overflow stream from the fresh water tank.
ID:	34252   Click image for larger version
Name:	location of overflow pipe.jpg
ID:	34253   Click image for larger version
ID:	34254   Click image for larger version
ID:	34255   Click image for larger version
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
