Old 08-02-2017, 02:28 PM   #1
Microwave
We just got our Mirada 29ds, we had a 5th wheel that had a convection/ microwave in it.
The wife got spoiled using the convection/microwave.
My question is has anyone one changed out the microwave to a convection/microwave.
Thanks,
J. Whaley
If so what was the model you used?
birddog55 is offline   Reply With Quote
Old 08-02-2017, 03:51 PM   #2
World Wide Wanderer
wahoonc's Avatar
As long as it fits the hole it shouldn't be a problem. My 2016 Coachmen Concord came from the factory with a micro/convection oven. We love it... most of the time.
The brand installed is a High Pointe. Going to be kind of expensive to put one in, they seem to run in the $400+ range. Make sure to read the reviews some are better than others.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 08-02-2017, 04:59 PM   #3
Ours came with it. My wife and I love it. Another High Point one. Wish you well,
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is offline   Reply With Quote
Old 08-03-2017, 08:14 AM   #4
clr
I have a friend that has a convention microwave for sale. I sent you a PM private message but you have not responded. He is leaving for the FROG rally tomorrow and will be trying to sell it at the garage sale. Respond to my PM and I will try and put you two in touch with each other.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 08-03-2017, 08:24 AM   #5
I just changed out my High Point MW for a Dometric Convection/MW in the 5th wheel, not a big job but did need to also change the 20 amp breaker for a 30.
Camper world $200.00
Retired Navy
Indiana
Hemisphere Lite 327RE
Silverado 2500HD 4x4 6.0 gas
Sailor Bill is offline   Reply With Quote
Old 08-03-2017, 08:37 AM   #6
Birdog:
I am in the appliance business and if you want to install a unit that is both a conventional oven and microwave look at the GE Advantium oven. It is pricey but when you use it and see what it can do you will not be disappointed. None of the microwaves that come with these units are even near the quality or have the capabilities that you find in the common household brands. Go to Ge appliances.com to have a look.
Changing it up a bit
2017 40 ft Cardinal Estate
2014 SRW Chev Duramax 3500
Titan 50 gal fuel tank
Air Lift 7500 lb bags
changing it up a bit is offline   Reply With Quote
