Old 10-18-2016, 03:29 PM   #1
New 260DS On Order - Question on Satellite TV
I have ordered my first RV, a Coachmen Leprechaun 260DS.
The brochure states that it is pre-wired for Satellite TV. However, none of the dealers I spoke to can tell me just how it is wired. I have called and emailed the factory and not gotten a response.
Does anyone know if they are just referring to the cable tv inlet on the side of the coach, wiring on the roof for the optional King satellite dome, or otherwise.
I have tried to do my research on various forums about satellite tvs in RVs but was hoping to obtain some model specific information.
Thank you in advance for your thoughts.
pkaplan is offline   Reply With Quote
Old 10-21-2016, 03:45 AM   #2
B D HOWie's Avatar
Contact Ron Ross at Coachman.
(574) 534-3167
He was very helpful.
I will try to find his email. Typically replied within a couple days with email.
Enjoy your new MH.
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 4500 Chevrolet Chassis
Paul
B D HOWie is offline   Reply With Quote
Old 11-04-2016, 06:18 PM   #3
sgtlm17's Avatar
Don't know how you made out but if your coach has the f connector on the roof that is the prewire. Should have a dedicated wall plate with f connector inside.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 11-05-2016, 04:43 AM   #4
World Wide Wanderer
wahoonc's Avatar
Typically it means there is a wire run to the roof area for the connections. On my Concord there is a plate on the roof, the wiring is under that plate for the King Dome. IIRC on the Concord you could order the King Dome from the factory, it was on the options list. If you look just to the left side (left in the picture) of the vent closest to the ladder you will see a small plate that has been caulked in place. That is where the connections on my unit are for the King Dome.
As far as the Leprechaun is concerned I would look at the roof of a similar unit and see if the mounting plate is there.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 11-15-2016, 09:24 AM   #5
Tder1's Avatar
Hi, 2015 Encounter but might be close, Yes there should be plate on the roof,mine was labeled for Satellite Connection. Up front above in the right cabinet there is a wall plate perhaps with a jumper where all your connections are made. I added a second wire to the roof because my T4 has dual connections. When I bought mine nobody knew anything about the wiring. I asked and got blank faces. Had to find it and figure it out myself which you will do alot. Hope this helps. The jacks on the outsides are really just to hook up cable. Attached print of system.
Tder1 is offline   Reply With Quote
Old 12-02-2016, 03:48 PM   #6
B D HOWie's Avatar
(574) 534-3167
Enjoy your new MH.
Paul
Found Ron's email
RRoss@ForestRiverinc.com
Paul
Paul
satellite
