Old 03-13-2018, 11:24 AM   #1
jegstrup's Avatar
New to class c motorhomes
Before now, I had a class A bit decided to downsize into a class c. I bought a brand new Coachmen Leprechaun 260DS.
My question is about converter vs inverter.
What I致e found is that unless I知 plugged into shore power or generator, I have only power to my lights, no electrical outlets.
Is this normal?
jegstrup is offline   Reply With Quote
Old 03-13-2018, 11:29 AM   #2
Your coach had a converter that transforms grid AC to 12VDC and charges the house batteries. Off-grid AC requires a generator or large inverter with a large storage battery bank, usually backed up with a medium to large solar system, a large expense. Less costly while off-grid boondocking would be use of 12 VDC equipment and propane for heating, etc
landsail is offline   Reply With Quote
Old 03-13-2018, 12:37 PM   #3
jegstrup's Avatar
Thx! I知 used to switching in the inverter in the class a when I知 off grid. I知 still adjusting to class c life.
Old 03-13-2018, 01:45 PM   #4
bikendan's Avatar
A class A has WAY more room for a big bank of batteries, than a class C does.
That's why class C's don't usually come with a factory inverter.
Equalizer WDH
Old 03-14-2018, 10:35 PM   #5
Jegstrup, this is normal unless you have a residential refrigerator. Then it comes equipped with a couple outlets that work with the two 6 volts batteries.
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is online now   Reply With Quote
Old 03-15-2018, 12:40 AM   #6
jegstrup's Avatar
I値l buy a small, maybe 500w, inverter and hook it up to the battery bank so I can charge phone and laptop
Old 03-15-2018, 09:37 AM   #7
Smile Small electronics charging
Using a 500 watt inverter to charge laptops, iPads, phones wastes a lot of energy because of the heat generated converting DC to AC and again back to 5-26 VDC for personal electronics. A better solution is to purchase 12 VDC to 5 to 26 VDC (laptop) chargers (Amazon). Less energy waste. Inverters also do not reach their 90-95% efficiency unless near their rating (in your example 500 watts). I am able in my Class C to run a 19 in LCD tv with DVD player (12 VDC) and a satellite receiver (w/o hard drive DVR) with about 26 watts or 2.0 amps @13 VDC. Very little battery capacity reduction and about 1 hour in the morning with 200 watts solar charging using tilt adjustable racking (one panel rotates with small ropes) brings my AGM battery system up to maximum. I can provide photos of my installation. Mark H, Electrical Engineer
Old 03-15-2018, 09:40 AM   #8
Smile Small Electronics Addn
I forgot, I use a small 75 to 100 watt inverter to run my Directv receiver (non DVD). It draws less that 10 watts of the 26-30 watts to run my 19 in HDTV and receiver.
Old 03-16-2018, 05:09 AM   #9
World Wide Wanderer
wahoonc's Avatar
Is this normal?
Yes.
You can certainly add an inverter, however make sure you have the battery capacity to support what ever you install.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 03-28-2018, 08:02 PM   #10
And many of us are trying to figure out how to wire an inverter into the 120V wiring of a Class C
robjordan406 is offline   Reply With Quote
class c, motorhome
