Old 06-19-2017, 12:16 PM   #1
No 12 volt after charging battery.
2015 Mirada 35KB
Pulled the two 6 volt batteries out to charge them at home, after re-installing them (in series) and reading 12.6 volts across them I turned the battery disconnect switch to ON and am getting nothing, no 12 volt systems work, nothing to the 12 volt side of the panel. Didn't have time to do any in depth trouble shooting, just some basic checks, 12 volts through disconnect switch is all.
Does anyone have a 12 volt wiring schematic for a 35KB or the location of all inline fuses/circuit breakers from battery box area to service panel.
DonH0348 is offline   Reply With Quote
Old 06-19-2017, 05:47 PM   #2
Did you happen to connect them backwards? If so, you blew the reverse polarity fuses at the converter/charger.
Gotta go campin!
Old 06-19-2017, 05:52 PM   #3
Originally Posted by DonH0348 View Post
2015 Mirada 35KB
You have "bigger problems" - possibly dead batteries. After charging, batteries should be 12.8-13.2 Vdc. If reading 12.6, I would use a load tester and verify that they are not in fact dead.
270S is offline   Reply With Quote
Old 06-19-2017, 06:02 PM   #4
My bet is its your converter
Mdaniels4 is offline   Reply With Quote
12 volt, battery, charging
