Old 02-16-2016, 03:50 PM   #11
Originally Posted by RedLdr1 View Post
For info the M-B Sprinter chassis, not Coachman specific issues, we now have the Mercedes Benz Sprinter Chassis forum. While it mostly FR owners most of the chassis "stuff" will apply to you as well. If you haven't already take a look at it...
That's a 'Youuuuuuge' help! Kinda wonder what I was missing. Prism may be a bit of a orphan because of the Sprinter drivetrain?
I'll follow the link and make some new enemies over there as well. Thanks!!
Byron in TX is offline   Reply With Quote
Old 02-16-2016, 04:49 PM   #12
RedLdr1's Avatar
The FR MBS versions can have the same "orphan" feeling in the larger Forester and Sunseeker forums. There aren't a lot of us and our configurations are different than the domestic chassis rigs.
There are five Sprinter versions, you are the orphan in a sense, as the other four; Isata3, Forester MBS, Solera MBS, and Sunseeker MBS are pretty close to each other with only paint and trim, separating them. The Solera has been discontinued this year and replaced with the Forester and Sunseeker versions. The Isata 3 is the new higher end version of the group.
But under the FR skin they are all Sprinters so you might as well hang out with us...
Wayne
2017 Sunseeker GTS 2800 QSF
TOAD: 2016 Ford Edge Titanium FWD
RedLdr1 is offline   Reply With Quote
Old 02-16-2016, 05:10 PM   #13
Cool and thanks!
I shopped the engine/chassis first and the box, well, not so much. If so, I probably would have gotten the used Thor Chateau I was also looking at.
But it was 2 yo and had 30k on it....albeit with much nicer interior appointments.
Price was 2k above what I paid new and the floorplan on the new one is superior (to us).
I can live with a lumpy mattress or crap cabinets....the 'bones' are what worry me.
thanks again!
Old 02-16-2016, 05:16 PM   #14
thanks again, Redldr:
Is the Prism considered a low end, substandard, or otherwise problematic motorhome?
Dearth of info during my research......just wondering if it's because they're aren't a lot of them that you don't find much?
Thanks.
Old 02-16-2016, 05:38 PM   #15
RedLdr1's Avatar
Not to my knowledge...I've always considered Coachman to be a good product.
You guys are just outside the traditional FR "fold" if you will. Someone at FR corporate decided not to integrate Coachman, like the other acquisitions, I guess. Probably because of the brand recognition Coachman has in the market. You can't access Coachman from the main FR website so a lot of folks probably don't even know it is owned by FR. Plus your units aren't made at the same plants as Forester and Sunseeker Class C so they are different than FR. That being said your floor plan is basically the "R" floor plan sold by FR. And you only have one forum here for all of Coachman so you MBS guys can get lost really fast...
Wayne
Old 02-17-2016, 02:04 PM   #16
Calbucano
I bought a 2015 Prism 24G in May last year. It does a fine job and yes, there were/are a few fit and finish issues and yes, it took awhile for Forest River to respond to a couple of warranty parts replacements. One of which was the check valve for the black water flush which was installed backwards. I didn't use the selling dealer who was pretty clueless about the MH. Instead I took it to another dealer who sells FR products and is much closer to home.
You might find the MH really rocks and sways when you go into a gas station or driveway. Some call it the Walmart Waltz. I found something called a "rockguard" which mounts above the rear wheels to protect some wiring harnesses and the propane hose to the hot water heater. It had 5 holes for mounting, but only 3 were used and when I discovered it, it was hanging vertically from the last 1. Clearly the rear wheels had bottomed out and dislodged the rock guard. ( I had weighed the MH and it was within specs. ) I called Forest River (Ron Ross) and was told the only real solution would be airbags. But I could't find airbags for the Sprinter 3500. We were about to head south (December 2015) and needed a solution. First I wrapped firehose around the wiring and hoses and remounted the rock guard (with all 5 screws). Then I found this place (Sprinter Suspension Upgrades – Sprinter Upgrades) and ordered the whole kit (shocks, swaybar, Sumo Springs etc) and had them installed. A huge difference! A little expensive but very comforting on the road. I had read about these suspension upgrades in other Sprinter blogs and the reviews were all positive. The folks at the Sprinter Upgrade place are totally familiar with Sprinter RV's and most helpful. I have no idea if this would be a warranty item but suspect it would entail a protracted argument between FR and Mercedes Benz. We had to get going so I just solved it. Total cost installed $2300. I suspect I paid too much for the installation labor but whatever.
Other than that, we had a great time in rather chilly Florida and I really love driving the MH. DW does as well.
Enjoy.
Tom
Coachmen Prism 24G 2015
calbucano is offline   Reply With Quote
Old 02-17-2016, 02:21 PM   #17
Thank you, Tom. Extremely helpful!
Old 02-17-2016, 03:14 PM   #18
TARVIDSON
x2 on everything Calbucano said except I haven't had the bottoming out problem he has and have not modified the suspension although I have thought about it to get rid of the slow speed roll. It is interesting that despite the roll at slow speeds on uneven terrain the unit goes down the road much straighter and with less driver input than the Ford Chassis units so I have just gotten used to it. Mine was purchased May of 2014 and I have 17,000 miles on it. From what I have seen the Coachman product seems to be about on a par with about every other motorhome I have looked at. As mentioned the actual coach is designed by completely different people than the Soleras. The slide mechanisms and all the little details may be the same or different from what look like nearly identical rigs. As to your bed, get a 3 or 4" memory foam cover and it will do wonders for your sleeping comfort. Most of the information on the forum will be valuable even if it is about totally different units as it will educate you about a whole lot of stuff that would take years to learn in just a short while. We have had a great time in the last two years and started out as compete newbies just like you. Have a great time!
TARVIDSON is offline   Reply With Quote
Old 02-17-2016, 03:18 PM   #19
Brilliant!! you're right....it's a bit like drinking from a fire hose right now, but lots of great tips. Esp the foam topper.....wouldn't have thought of that and it's way cheaper than marriage counseling. Thanks!
Old 02-17-2016, 07:57 PM   #20
Love our 2015 Prism
Lots of modifications later we are still settling into our unit.
Helwig sway bar, Sumo springs, MaxAir powered vents, some drawers in the dinette base. Definitely a memory foam mattress topper. Going to change the MB Sprinter horn and upgrade the speakers in the doors next.
Welcome to the RV forum.
Iowaprism is offline   Reply With Quote
