Old 03-23-2016, 09:24 AM   #21
Kenny kustom's Avatar
Originally Posted by Wolverine 1945 View Post
Thanks Kenny for the advice !!!
What do you think about using it in Lawn Tractors ???
Same thing,,, only use in Old Tractor \Engines ???
Ive never used it in anything. Others might have a different opinion.
If you have a leaky seal, an additive isnt going to fix that.
I run a good syn all year round. ( Canada = cold )
Old 03-23-2016, 09:33 AM   #22
Wolverine 1945's Avatar
Thanks again Kenny,,, I have been using Mobil 1 now for a few years !!!
I think it only a couple bucks more ???
Wolverine 1945 is offline   Reply With Quote
Old 03-25-2016, 06:16 PM   #23
I registered mine on the Ford site and it tells me my next service is 7500 miles.
AbdRahim is offline   Reply With Quote
Old 03-26-2016, 07:22 AM   #24
It did not list a time limit ???
Old 03-26-2016, 07:45 PM   #25
No.
Old 03-27-2016, 08:12 AM   #26
I have always been one to over service things,,, I am a big believer in Lub & Service,,, & preventive maintenance of every thing I own !!! I change the filters & oil in my lawn tractors way before the recommendations !!! But maybe I dropped the ball on our V-10,,, we have a 2013 Sunseeker that we bought new in 2014,,, so it is really 3 years + old,,, we have just under 4K miles on it and the original oil !!!
Which I will be changing before our first trip this year !!!
Old 03-27-2016, 08:52 AM   #27
RedLdr1's Avatar
For the Ford recommended oil change frequency see the Scheduled Maintenance Section of your Ford Owners Manual. For the 2016 chassis the E-450 chassis the manual states:
NORMAL SCHEDULED MAINTENANCE
Every 7500 miles (12000 km) or six months (whichever comes first)
Change engine oil and filter.
Rotate tires*, inspect tire wear and measure tread depth.
Inspect wheels and related components for abnormal noise, wear, looseness or drag.
Perform multi-point inspection (recommended).
* Vehicles with dual rear wheels should rotate the front wheels when specified; rear wheels only if unusual wear is noted.
That is from Page 271 in the 2016 E-450 Owners Manual. You can download a .pdf copy of the Ford Owners Manuals Here.
It's interesting they don't recommend regular rotation of the rear duals...
Wayne and Christine
2019 Sunseeker 2500TSF Pending Delivery...
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 03-27-2016, 09:05 AM   #28
My thoughts are than 7500 miles is to far,,, 5000 would be max for me,,,
But I think 6 months is to soon,,, for us that could be ever 2000 miles !!!
Not arguing with FORD,,, they know a hell of a lot more than I do !!!
I have been buying FORDS since 1962 !!!
At this time we own,,,
2003 F-150
2011 EDGE
2013 V-10
Old 03-27-2016, 09:09 AM   #29
Dodge Guy's Avatar
If you change the oil and park it there is no reason to change the oil in the spring. Keep the oil changed and you will be fine. The 6 month limit is for short trippers (like me) who only drive 4K miles a year. That builds up a lot of moisture which leads to corrosion and acidic elements in the oil. Changing the oil and parking it for 5-6 months will not hurt anything.
Then again, $100k for a MH.........one extra $40-$50 oil change a year is nothing.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 03-27-2016, 08:26 PM   #30
Wow $200 in oil change every 3000 miles does seem excessive.
ford
