Old 03-21-2016, 12:00 AM   #1
Oil change interval on Ford V-10
I have a 2016 Leprechaun 319DS with a Ford V-10. The manual says that the oil must be changed every six months or the warranty may not be any good. I'm getting the oil changed now at 22K miles and will begin my RV season. Say I drive 5000 miles by September, change the oil again and shut her down for the winter. Do they really expect me to change the oil again in March, 2017 after not driving it all winter? Do people really do this? Thanx.
pobox1067 is offline   Reply With Quote
Old 03-21-2016, 05:28 AM   #2
Kenny kustom's Avatar
Yup
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 03-21-2016, 06:20 AM   #3
Yes, The idea being to keep moisture and acid content in the oil in check. If you took an oil sample it would probably be fine. We go up to a year in our fleet vehicles that sit seasonally if they are out of warranty.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 03-21-2016, 10:01 AM   #4
Thanx Mars. "if they are out of warranty." That's the rub. If mine were out of warranty, we wouldn't be having this dialogue. But I'm expected to dump out seven quarts of unused oil (and filter) just to satisfy the warranty requirements.
Old 03-21-2016, 10:49 AM   #5
Unused, maybe.
Condensation, yes.
2016 Sabre 36QBOK
Old 03-21-2016, 10:53 AM   #6
Send a message via AIM to NoviBill
Not sure where people get their oil changed, but my local Ford Dealer runs about $40. Compared to an engine rebuild, it's a steel.
Bill & Renee from Novi, Michigan
2006 Lexington 255DS
http://anunbalancedbalance.blogspot.com/
NoviBill is offline   Reply With Quote
Old 03-21-2016, 10:57 AM   #7
The same question cam up just last week.
Except that was in the Sprinter section.
$100k plus rigs, worrying about an oil change...
Old 03-21-2016, 11:18 AM   #8
Myself I change every spring regardless since I run the engine at least once a month in the winter. I know there is condensation in oil.
Myrle is offline   Reply With Quote
Old 03-21-2016, 11:24 AM   #9
Since I put on less than 4,000 miles per year, I change my oil once a year. However I put in synthetic oil which I believe is less prone to the problems of non synthetic oil. I hope I am right.
papakilo is offline   Reply With Quote
Old 03-21-2016, 12:03 PM   #10
Makes sense...but the factory doesn't let you extend the interval if you use synthetic. And, in fact, they recommend synthetic even while demanding change every six months.
ford
