Old 02-24-2017, 10:05 AM   #201
hammer55's Avatar
thanks, will do, it is even hard to get to the fuses on these too, but didn't know about them,,,,
Originally Posted by ResQfrog View Post
Check the fuses first. Ford normally has separate ones for the seven pin connector. Also that seven pin plug is not the most water proof one. Replacing ours soon with and molded one with short wiring harness with heat shrink crimp connectors.
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 02-24-2017, 10:15 AM   #202
If I'm not mistaken it was in the under hood fuse box. The fuse boxes under the dash cover the dash board and Coachmen stuff.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 02-24-2017, 10:57 AM   #203
hammer55's Avatar
thanks, I will check there first
Mark & Annie
Old 02-27-2017, 03:22 PM   #204
hammer55's Avatar
ResQfrog,, thanks for the heads up about the fuse, even though all the fuses are under the dash, and took me a while to find the manual and down load it, I found it and it was the fuse, thanks for the heads up,,,
Now I will work to re-seal the plug to eliminate future problems,,
Mark & Annie
Old 02-27-2017, 07:21 PM   #205
I'm actually going to replace mine with one that is expoxy sealed and also has a flat four connector with it. Then the harness has heat shrink crimp connectors. Will then seal the whole harness with heat shrink tape.
FROG Member
Old 03-29-2017, 10:52 AM   #206
hammer55's Avatar
slide out seal,
the foam seal on my slide out is where the leak has come from, what seal has anyone use to replace their original seal with,,,, any ideas
Mark & Annie
Old 04-09-2017, 07:27 AM   #207
Certified Curmudgeon
Mine leaked at the front lower corner due to the gear being
one tooth off and not sealing. With the slide repair, all the seals
were replaced and installed properly. The only change to stock is a
much larger D seal along the bottom edge to keep the road spray and
bugs out.
Mike Dropped
