Old 05-14-2018, 06:50 PM   #1
Outside tv
How do you remove the outside tv.
Gdbarker is offline   Reply With Quote
Old 05-14-2018, 07:57 PM   #2
bikendan's Avatar
You need to post year/make/model of RV that you're asking about.
It's not listed in your profile.
It varies wildly between brands and models.
Old 05-14-2018, 08:58 PM   #3
Sorry new here was first post. 2016 Coachmen Pursuit PSA29SBPF. I have tried pulling straight out to the side. If you know how In would very appreciate your help.
Old 05-14-2018, 09:05 PM   #4
Sorry new here. 2016 Coachmen Pursuit PSA29SBPF. If you know how I would appreciate it. I have pulled straight out from one side nothing seems to give.
Old 05-15-2018, 10:05 PM   #5
Jeff6146's Avatar
Isn’t it on a mount. Most are on wall mounts. Screws are taken out from the back.
Jeff6146 is offline   Reply With Quote
Old 05-17-2018, 11:27 AM   #6
It's mounted to a standard wall mount. You get two people and gently raise it straight up until free from mount
ENGINEER is offline   Reply With Quote
Old 05-25-2018, 10:56 AM   #7
There are many kinds of mounts. As Engineer said, it might be as easy as lifting it off the mount. The wall mount for our bedroom TV has 2 set screws reachable from below the TV. Loosen them up and the TV will lift off the mount. Get a flashlight and look behind the TV from the bottom, both sides and the top if you can reach it to see what king of mount you have. I have seen V-shape tongue and groove, set screw like ours, lever locks, pintle type and other kinds of TV mountings. Seems each company has their own version.
Ozarkryder is offline   Reply With Quote
Old 05-31-2018, 09:43 AM   #8
Our Freelander outside TV required removing the back panel of the compartment and lifting the panel/TV out as a unit. Once out, the mount was screwed on from the back side of the panel. I replaced that mount with a swivel assembly so it would be easier to view the TV.
The back panel was held in with four screws, one in each corner. Very hard to see as they were buried in the fabric covering the back panel.
Hope this helps,
Gary
Safe Travels,
Gary
2015 Freelander 28QB
Wrangler JKU
Funtwodrv is offline   Reply With Quote
