Old 06-30-2015, 08:14 AM   #1
Voortrekker's Avatar
Parasitic drain from Magnum Energy meter...
I have a 2014 SportsCoach Cross Country. When I turn OFF the coach/house battery switch the Magnum Energy meter (upper meter) remains energized. The lower meter (showing the power connection), however, is de-energized when the coach/house batter switch is OFF.
I'm concerned that the upper meter will provide enough parasitic drain to decrease the battery power during any storage period.
Do any of you Cross Country owners have a similar situation? Or does your upper meter "go to sleep" when the switch is turned off?
If anyone know the "fix" for this, I'd appreciate hearing about it.
Thanks....
'14 Coachmen SportsCoach Cross Country 404RB
'15 Jeep Wrangler Unlimited--TOAD
Voortrekker is offline   Reply With Quote
Old 06-30-2015, 11:46 AM   #2
Follow-up....
Well....I think I have it figured out. On top of the Charger/Inverter box are four RJ-11 plugs. One is labeled "Remote." If I disconnect that plug, the meter goes out/turns off. Hence pulling that plug should eliminate the parasitic drain. It's a bit awkward to do that...but it should work.
I guess the logic of having the meter powered full time is this: The remote unit allows one to program various events to automatically start the genset. For example, some folks set it to a particular time or temperature so that the dog or grandma don't get too hot 'cause the AC will come on.
Oh, well....our dog died long ago....and grandma (usually) goes home with me.
Camp ON....Voor
drain
