Old 08-19-2015, 04:02 PM   #1
Chewie's Avatar
Pursuit 33bh anyone?
Does anyone have one of these? We were looking to get out of the 5th wheel and into a Class A. Any pros/cons? Thanks
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 08-25-2015, 06:11 PM   #2
Chewie's Avatar
Anyone have this floor plan?
Old 08-25-2015, 09:02 PM   #3
Former Full Timer
Duckogram's Avatar
A search of the forum yielded 0 results. I'm going to venture a guess that a 33' bunkhouse on an 18k chassis is not the best plan but for $80k you get a fair amount of bang for you buck.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 08-26-2015, 08:29 AM   #4
Chewie's Avatar
Most of the bunkhouses we've been looking at 31-33 feet all have the same F53 18k chassis. Is this not enough? I've looked at the Winnebago Vista, Fleetwood Storm, and the Pursuit. None give an option for the heavier chassis, at least that's what we were told. New to the motorhome stuff so any help is appreciated. Thanks
Old 08-26-2015, 07:10 PM   #5
Former Full Timer
Duckogram's Avatar
Look at Vista LX 35T and Baystar Sport 3004 & 3306. The 35T is in the price range but slightly larger. There are others as well. Here is some fuzzy math for you:
15,000 wet weight (conservative estimate)
6 people
all the toys
dogs
DW's shoes
Food
Clothes
Then add water for boondocking
Still think 18k is enough?
You planning on bringing the trailer?
Old 08-26-2015, 08:11 PM   #6
Chewie's Avatar
I understand payloads and weights but the one we are looking at has no other chassis option. I'm trying to find the published weight on it to see what payload it has.
Old 08-27-2015, 11:14 AM   #7
Former Full Timer
Duckogram's Avatar
There is no published weight as each unit is weighed and labled at plant310. You can get an "average" by calling a dealer that has one and ask what the Cargo Carrying Capacity is on the little yellow label.
That 15k lb wet estimate I used is going to be pretty close as my 27KB is labeled 13,500 lbs. ...
So what I was trying to relate to you is that you will have about 3000 lbs for everything. Will that be enough for your intended use? Probably, but you will be at the top end. Basically, I just don't think thats the best plan which is why I brought it up.
Good luck with whatever you decide.
Old 08-27-2015, 11:58 AM   #8
Chewie's Avatar
We are packed pretty light in the 5th wheel and planned on scaling that down to fit into a smaller unit. Let me ask you, how do you factor in a toad? My understanding is if I dolly tow, the tongue weight is factored into the usable payload. What about flat towing? I'm assuming there is no tongue load figured in?
Old 08-27-2015, 06:54 PM   #9
Chewie's Avatar
The one pursuit has 2068 lbs in reserve, not much.
Old 08-27-2015, 07:09 PM   #10
Former Full Timer
Duckogram's Avatar
Flat tow only adds the weight full weight of the toad to the combined gross or CGVWR which is 23k for the 18k chassis. For dolly @ trailer applications you have 5000 lbs max and 500 lbs on the hitch. The 500lbs goes against your GVWR.
