Old 08-12-2018, 12:39 PM   #1
Pursuit Headlight LED Halo Ring
Any of you Pursuit drivers ever have a headlight LED halo ring go out? If so how do you change them?
ID:	183006   Click image for larger version
2016 Pursuit 33BH,
2012 Jeep Wrangler,
2013 Honda 50CH
Blue OX
cberlanga is offline   Reply With Quote
Old 08-12-2018, 07:37 PM   #2
I believe that you have to change out the whole headlamp assembly.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is online now   Reply With Quote
Old 08-14-2018, 05:05 PM   #3
Any luck figuring it out?
52chevy is offline   Reply With Quote
Old 08-16-2018, 09:06 AM   #4
Looking on You Tube, the assembly has to be removed, the clear plastic cover heated and removed to get to the halo ring. Then measure the size of the ring and order a replacement (from Amazon). I cannot find a complete new assembly online. That's what I figured out.
2016 Pursuit 33BH,
2012 Jeep Wrangler,
2013 Honda 50CH
Blue OX
Old 08-17-2018, 12:19 AM   #5
1sd
I replaced the headlights in my '16 Mirada because the original ones "delaminated". If yours are from the same manufacturer, they're made by "Angel Eyes". Cheap Chinese junk that Coachmen installs. Yours look similar to the Mirada so they should be replacements for 2013-2014ish Tahoe. Google "Angel Eyes headlights" and "Tahoe" and see what comes up.
1sd is offline   Reply With Quote
Old 08-19-2018, 10:52 AM   #6
The clear coat on that headlight assembly was peeling also. I did the restoration procedure using wet sandpaper and Meguiars polish followed by a synthetic wax sealant. Its not 100% crystal clear but close enough.
2016 Pursuit 33BH,
2012 Jeep Wrangler,
2013 Honda 50CH
Blue OX
led, light
