Old 04-11-2015, 09:19 PM   #1
Racking up miles when towing Ram 1500?
Can anyone tell me if I will rack up miles when towing my Ram 1500 4X4 behind my Class A RV? If yes, is there any way to circumvent this?
GlennFC is offline   Reply With Quote
Old 04-14-2015, 06:44 AM   #2
hammer55's Avatar
not that I know the answer, but are you not racking up miles, the truck is being pulled how ever many miles your rv travels, just my take on it, the only difference is the engine is not doing the racking
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 04-14-2015, 06:59 AM   #3
mlong's Avatar
You will rack up miles while towing it. The only way to get around it is to use a trailer so the wheels are not turning.
2012 Chevy Silverado Crew Cab Short bed 5.3L v8
2014 Prime Time Manufacturing Avenger ATI 27BBS
mlong is offline   Reply With Quote
Old 04-14-2015, 07:17 AM   #4
Ashley's Avatar
You don't state what year the Ram is but assuming it is anywhere from the late 90s on I would say, IMO of course, that no it isn't going to count mileage unless the key is in the on position where the Powertrain Control Module is powered up. The vehicle speed on the vehicle is produced electronically, depending on year model, either using the rear axle speed sensor or the transmission/transfer case output speed sensor.
If you will give the exact year model, transmission type and engine size I will verify my above statement. If the above is not so, I may be able to tell you a particular fuse to pull when towing so mileage is not counted up while towing.
2008 Dodge Ram 3500 MegaCab 6.7 Cummins
4x4, 4.10 Gears, 68RFE Trans
2012 Primetime Lacrosse 318 BHS
Ashley is offline   Reply With Quote
Old 04-14-2015, 08:54 AM   #5
5er_tom's Avatar
A friend towed a Chevy HHR, the odometer did not record the mileage when towed.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is online now   Reply With Quote
Old 04-14-2015, 08:59 AM   #6
mlong's Avatar
Good point here. I was thinking of the old analog rotary odometers for some reason.
Old 04-16-2015, 07:17 AM   #7
My truck is a 2011. I think it makes sense that unless the key is on the odometer should not record the miles towed. I will be doing a test run soon and will confirm what actually happens when I do.
Thanks everyone for your input.
Old 04-16-2015, 07:40 AM   #8
PhoneDude 8289's Avatar
Turn key on and record milage turn key off. At the end of a days drive or next stop turn key on again and record milage, there is your answer.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 04-16-2015, 08:10 AM   #9
Sounds like a good reason to NEVER buy a vehicle that has been towed- if you can tell. That thing can have a LOT of unregistered miles on the axles, suspension, brakes, etc. Obviously not the same as driving it since the engine won't have those miles, but still some wear and tear that is unaccounted for.
Old 04-16-2015, 08:24 AM   #10
RSchleder's Avatar
I have towed 3 different vehicles 4 wheels down, a Honda CRV, a Mini Cooper S, and a GMC terrain. Miles did not accumulate on the speedo on any of the 3.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
500, towing
