Old 09-29-2015, 11:32 AM   #1
Relay for the LCI leveling and windshield wipers...
I have a 2013 SportsCoach Cross Country.
Recently, when I first start the rig, I get no power to the LCI Leveling system nor the windshield wipers. This tells me that it's a relay that isn't functioning when powered up. I've looked in the electrical bay and don't see a relay labled for leveling system nor windshield wipers. Nothing in manual either.
Anyone have knowledge of where the relay can be found?
Thanks in advance,
Keith M.
2013 Coachmen SportsCoach 385DS
Maladjusted is offline   Reply With Quote
Old 10-10-2015, 10:33 AM   #2
Roll's Avatar
You might do better to tap into a line that has several SportsCoach or Pathfinder owners participating.
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 10-10-2015, 10:37 AM   #3
Thanks, do you know of any discussion groups that support the SportsCoach and Pathfinder models?
Thanks,
Mal
Old 10-10-2015, 10:40 AM   #4
Witch Doctor's Avatar
Look next to your LCI pump should be a red reset located there see if that tripped on you. Not quite sure why your wipers would connected to your LCI leveling system?
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-10-2015, 11:21 AM   #5
Thanks gljurczyk. I don't think that reset is the issue. When the LCI panel has no power, neither do the wipers, nor the power mirrors. If I cycle the ignition and the coach power switch a few times, so far the power has come back to the LCI panel, the wipers and the mirrors.
Coachman tech support was very little help. The did send me the wiring schematic... I am just not well versed in reading wiring schematics.
I'll just have to start studying them to find the circuit. There has to be a relay or loose connection somewhere.
Thanks for the reply and suggestion though. (I will check that reset when the outage occurs again)
Mal
Old 10-10-2015, 11:53 AM   #6
Mal
If it comes and go's sounds like more of a loose connection, can't be a fuse. Next time your screen comes on check for your voltage with up or down arrow. Good luck the support is really kinda of useless most times. I'm surprised they sent you a schematic even....Good luck you will find it....
Coachmen M/H
Concord
2018 / 300 DSC
leveling
