Old 01-11-2016, 06:06 AM   #1
Semi-technical AC question
I have a 2009 Freelander with Ducted AC as well as the grill over the AC allowing direct flow into the camper.
When I had the grill/return filter off for another reason the other day I noticed that someone before me had purposefully opened a passage between the discharge and return. Why would someone do this? Common sense would say repair it but why would it have been done? I'm afraid to correct until I find out.
KAttkisson is offline   Reply With Quote
Old 01-11-2016, 06:31 AM   #2
TURBS's Avatar
Should be totally blocked off
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-11-2016, 06:50 AM   #3
R3Jones's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
I agree. This short circuiting can cause a freeze up situation.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
R3Jones is offline   Reply With Quote
Old 01-12-2016, 09:42 AM   #4
Former Full Timer
Duckogram's Avatar
That makes no sense. The return air must be isolated from the discharge outlet. Sound like old Knuckles McGirk was at it again.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 01-12-2016, 09:51 AM   #5
Left Coast
Reneck thermostat?
Old 01-12-2016, 10:43 AM   #6
Witch Doctor's Avatar
Some people think that it will cause a lower delta T between the R/A and the Supply air. The thinking it will cool the trailer down sooner. Will not happen. In fact it will take longer being an A/C is only a large dehumidifier. Some units come with a sensor on the evap coil , what will happen is that you would freeze the coil sooner. Also some do not have a sensor. If you don't have a heat load and the outside amb. air drops you will freeze that coil. Close it up, you can't cure stupid but you can correct it.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 01-12-2016, 10:48 AM   #7
Head Rambler
In a previous RV there was several 'leaks' between the supply and return air plenum. I used insulated foam duct tape to seal them up and after that the unit cooled much better and we had no more freeze-ups.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
