Old 04-01-2015, 01:42 PM   #1
jjd74's Avatar
Slide controller readouts
So in looking over the coach I noticed this display blinking red and green. One green blink followed by six red blinks.
This is telling me there is a motor short circuit on one of the two motors?? The slide previously worked without issue though I'm afraid to check after seeing this pattern? Am I delusional and this is a normal blinking meaningless led or is something apparently still broken with my slide out?
What readout pattern currently displays on your slide out controller? Thanks for the info as always.
jjd74 is offline   Reply With Quote
Old 04-01-2015, 01:48 PM   #2
jjd74's Avatar
Meant to include pics.. Click image for larger version
Name:	ImageUploadedByForest River Forums1427914058.547052.jpg
ID:	72739Click image for larger version
Name:	ImageUploadedByForest River Forums1427914089.452344.jpg
Old 04-02-2015, 06:52 PM   #3
Former Full Timer
Duckogram's Avatar
That is a good question. I will go look tomorrow. A fault code of any kind cannot be normal.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 04-02-2015, 07:15 PM   #4
jjd74's Avatar
Thanks kindly! I've cycled the house power dial hoping for a change but it's the same pattern on reboot. One green and six red. Steps not retracting either and short circuit on a slide motor, say it ain't so..
Old 04-03-2015, 08:18 AM   #5
Former Full Timer
Duckogram's Avatar
Just turned the power on and checked the controller. No lights. Only a little spider crawling around in the compartment. I think motor 1 is the one by the bed so you might need a mirror to see if the harness that runs down the inside of the slide frame is damaged.
Old 04-03-2015, 08:53 AM   #6
jjd74's Avatar
Ugh. Apologies for disturbing mister spider. Thanks for the info!!
Old 04-03-2015, 08:54 AM   #7
Brother Les's Avatar
There are instructions on how to 'over ride' the box at the Lippert Components web site. Print them off. "I think" that you need to 'over ride' the program and let it 'relearn' the perimeters. There is a little button inside that cavity where the light is flashing. Push that button (it says on the box) I think 6 time and hold it down until the light flashes crazy like. Release the button and now try to move the slide and steps. The motor will 'count' the revolutions going out and coming in, it needs to 'relearn' its operation. If this does not help, call Lippert Components
Brother Les
Old 04-03-2015, 04:35 PM   #8
jjd74's Avatar
Interesting info. The slide was out of alignment and so I had to realign, I wonder if that did something. I'll look into it, thanks for the thought.
Old 04-03-2015, 04:39 PM   #9
That did it.... what I did in the past was 'over ride it' to get it going and then run it all the way out. Run it in a foot and run it out, do this about three or four time and it will know the out board length. then it should be fine to run it all the way it as it will 'count' the revolutions going in.
Brother Les
Old 04-03-2015, 06:45 PM   #10
Former Full Timer
Duckogram's Avatar
Am I blind or are the overide instructions right on the controller box pictured above???
controller, slide
