Old 08-25-2016, 06:04 AM   #11
Land of the Midnightsun
jjSpeedwagon's Avatar
Originally Posted by wahoonc View Post
My large slide is the same.
Bedroom slide is noisy, need to get in there and get it lubed.
And mama wants an electrical outlet on HER side of the bed...
Aaron
There is one. Look on side of bed towards floor. Lol
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 08-25-2016, 08:06 AM   #12
Yup, I have one too. As far as the slide corner being open I mean I can slide my fingers between the coach and gasket. Can't be right. We got home last night after two days and 1500 miles. All ok. I have to say this Concord is a pleasure to drive.
richardelarson is offline   Reply With Quote
Old 08-26-2016, 02:04 PM   #13
About the electrical outlet,,salesman said there is not one under booth,,there is !!!!
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 08-26-2016, 07:40 PM   #14
World Wide Wanderer
wahoonc's Avatar
That's MY side... she wants one on HER side. Not a big deal, just feed off the plug on my side and put one somewhere close to that corner.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 08-26-2016, 08:51 PM   #15
No, there is one on both sides on our unit.
Old 08-26-2016, 09:57 PM   #16
Aaron
Get on your hands and knees it's there. We are at big horn resort. They not kidden really nice place they have open bar from noon till u plant ur face in ground. Didn't plant. Thankful for our bikes. Kerrville tx.
John & Janice
Old 08-28-2016, 07:21 AM   #17
World Wide Wanderer
wahoonc's Avatar
Found the plug... even my wife missed it and she is usually very good at finding things (especially if I am involved )
I like the sound of that Big Horn resort...
Aaron
Aaron & Rhonda
Old 09-15-2016, 07:29 AM   #18
Here is an update on my slide problem. Remember when I was on the road and the big slide didn't come in right? I could slide my hand in the bottom front corner between the coach and gasket? Turns out that gear slipped a couple notches. I talked to the mechanic and learned they had to remove the gear/motor, push it in and re-install. Normally that would straighten out with a repeated in/out a couple times but not when a top or bottom gets out of whack. One motor drives the top and bottom gear on a shaft. So, good thing I didn't try to use it while on the road or damage would have resulted.
Old 09-16-2016, 02:27 AM   #19
Dlj_75's Avatar
Yeah I just got mine back from the shop. They had to work on all 3 of my slides. Said that the manufacturer didn't cut the opening with enough clearance which caused one of them to be in a bind, on the second one I was told the motors were not installed properly and then the final one got off track, they had reset it to proper track the last time I had it in when they worked on all 3 a couple months ago but on our way home from a trip this slide got off track again so I had to take it back in about a month ago. After a month of waiting they finally got coachmen to authorize the dealer to install a roller on this slide because it was too heavy which was causing it to get off track. So I'm hoping this time it is fixed.
Dlj_75 is offline   Reply With Quote
slide
