Old 11-27-2015, 09:15 PM   #1
Slides Leaking on Concord 300TS
Has anyone on this forum experienced leaking from their slides? This only occurs with the slides closed, either while our RV is stored or while driving in the rain. The water pools under the inside front corners of the front slides. We have absolutely no problem with water ingress with the slides out.
We have returned our 300TS to the dealership numerous times and they have been unable to find any leaks.
Any information or shared experience is appreciated.
Thanks in advance!
fltravelers is offline   Reply With Quote
Old 11-28-2015, 10:53 AM   #2
I have a 2014 Concord 301SS and noticed a small amount of water on the floor near the slide on two different occasions. I took it to the dealer and had a pressure test done. They could not find any leaks. Next rainfall there was water on the floor again. I did some checking around and found that the carpeting was wet where it wrapped around the floor of the dinette area slide. I pulled it back and saw water seeping from the bottom of the slide floor. I then called and spoke with both the dealer and manufacturer who both asked if it was parked on an angle (which it was because my driveway has a slight slope to it). To make a long story short, turned out that the window seep holes could not handle the rush of water caused by the sloped driveway and the water leaked down the inside wall and out of the bottom of the slide. Moved it to where I store it, which is level, and knock on wood, have not had any leaks since. Not sure if this is any help to you, but thought I would share, just in case.
bondo228 is offline   Reply With Quote
leak, slide, slide out
