Originally Posted by msbaker
anyone towing a smart car-have questions
I tow a 2011 Smart Fortwo Pure.
Have done so for over 25,000 miles. No bungee but I am familiar with the method. There is a downside to doing that.
It will cause a side load on the steering. Note: The Pure only has a 2 spoke steering wheel. The bungee will not work well on that. The Passion and Brabus have the 6o'clock spoke.
Here is an excerpt from something I wrote previously:
Congrats,
Now you're a Smartie!
I recommend the Roadmaster plate. It has a much better mounting design. I also use a Falcon 2 tow bar. Works just fine.
You MUST use a battery disconnect switch. I mounted mine on the upper right side of the shroud in front of the console in the passenger foot well. Its close to the battery and easy to install there.
I also use a "blade" key without the electronic fob attached. I do that because you have to leave the key in the ignition and you cannot lock the door after you disconnect the battery.
I use a laminated checklist every time.
I also changed the gearbox sauce at 30,000 miles because it gets hot and there is no cooling when you tow. You will smell it!
