We went with Helwig anti sway (helps moving or parked) and stabi-lite stabilizers. While we can still feel people movement a bit, the wind movement is gone for the most part.
Heavy sway bars are probably what I would do first, whether or not you want stabilizers or levelers.
Getting reasonably stable is what DW wanted, so she does not get shaken awake if someone moves around.
Look under your rig. Might already have the mounts for levelers added from factory, which would make it much easier for DIY.
I would not suggesting adding or jacking past the frame extension.
