Old 07-07-2013, 06:19 PM   #1
Roll's Avatar
This is definitely bizarre. Holding tank rinse spray.
I feel foolish even posting this but I am now certain the rinse nozzle is incorrectly installed in the grey tank not the holding /black tank.
Is it even possible such a mistake might be made during assembly?
I've used the rinse hookup only three times (I know, I should use is every time we dump), and each time something odd happened.
I can go into more detail but now after using it this weekend I am certain it is attached to the grey tank, not the holding tank. I plan to call Coachmen Monday morning to discuss. The coach is a 2011 and out of warranty I am certain but this is an assembly mishap and should be fully covered by Coachmen.
Roll
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 07-07-2013, 06:30 PM   #2
Oakman's Avatar
You have a 2011 Coachmen and you've only used the black tank rinse three times? The title of your post is dead on, this is definitely bizarre.
I've never heard of a black tank rinse hooked up to the wrong tank but I guess it could happen. More common is having the tank handles mislabeled.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 07-08-2013, 08:25 AM   #3
Roll's Avatar
They are not labeled. The right pull handle is on the smaller pipe and when the grey tank gets near full, it is the handle I pull to empty it. This is the tank where the rinse spray is installed.
I ran the rinse spray with the holding tank empty but before I had drained the full grey tank. When I turned on the water, I got spray back out of the shower drain and from a vent pipe under the sink. It was messy but it was not from the holding tank.
The left handle is on a much larger pipe and drains the holding/black tank.
Old 07-08-2013, 09:12 AM   #4
jevanb's Avatar
my black tank rinse was hooked up to my fresh vent
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 07-08-2013, 09:18 AM   #5
Roll's Avatar
Here is the full story....
1) Not long after taking delivery my sister and brother in law spent a couple of nights in the coach. I was new to the rig and whole hook up process. I mistakenly connected the shore water to the tank rinse instead of the "city water" line. I did have some water in the fresh water tank and the pump was on; (I know better now but I was new to all this at the time). They called me (several times) to come over and dump the grey tank which they kept an eye on at my instruction and seemed to be filling faster than the water they were using. I realized my mistake when I closed up the coach but never did question why the grey tank was filling so fast. Thought they were using more water than necessary which they denied. Clearly they were using little water but what they used came from the fresh water tank I had left partially filled with the pump on. The rinse was filling the grey tank which took some time since the grey tank is larger than the holding tank.
2) Months later I did use the rinse one time after draining both tanks but just did not notice that it was the grey tank that had a continued water flow, probably had both valves open at the time. Again did not consider that I might have a problem with the rinse function.
3) This weekend we filled the grey tank twice and each time I let a little out (full hookup site) so that when I did dump the holding tank I would have a nearly full grey tank to flush out the hose.
On closing the coach down I first turned on the rinse with a holding tank about 60% full and draining. (grey tank is closed and full at this time). Within a moment I had water draining all around the wet bay; obviously something was wrong. I shut down the rinse immediately and checked inside the coach. The bathroom floor was wet, the hall was wet and water was leaking out from under the kitchen sink. As the wife cleaned the bathroom floor she said it appeared the water came from the shower. It was wet from spray; toilet looked entirely normal, no water or debris inside the lid; I checked and did not suspect the rinse problem as yet. Actually I thought I had a broken water line from the rinse hookup.
Cleaned up the water (no odor of any consequence and it was clear water; no dark color, or blue color from the toilet chemicals I use). After we cleaned everything up and the holding tank had been drained I hooked up the rinse again and turned the water on slightly, (grey tank is still full). Wife inside coach gave out a yell and I turned off the rinse.
Water out of the shower drain again, and from under the sink (where I found a vent pipe attached under the cabinet running up the inside paneling). This is where the spray was coming from according to the wife who pointed at it while I held a flashlight on the vent. She had seen it spraying out.
Cleaned up again and drained the grey tank. Did not reconnect the rinse hose.
Even though the rinse was on only a minute or two, I did have the holding tank valve open while the grey tank was closed and no more water came from the holding tank.
Can you imagine any other explanation for these experiences? How otherwise, would turning on the rinse cause water to spray out of the shower drain or come out from the vent under the sink?
Roll
Old 08-24-2013, 05:07 PM   #6
2013leprechaun319dsf's Avatar
Roll, Did you get this resolved?
My Leprechaun 319DS came with 3 water attachments on the left side of the MH.
Only 2 were labeled (city hookup and black tank flush). Had to assume the third was for fresh water tank (it was). Called Coachmen and got the proper sticker to put over the third inlet.
Are your inlets labeled?
Do you use a pressure regulator when you hook up to a hose?
They could be mislabeled.
2013leprechaun319dsf is offline   Reply With Quote
