Old 06-20-2013, 02:56 PM   #11
Hugh R's Avatar
Hey,
So I got real metal tire valve extenders installed on the rears. They loaded the tires up to 98 psi. The fronts from the Dealer are at 90 PSI. The sticker in the Mirada states 82 psi. I'm thinking I should lower them all to the 82 that the sticker says. It was kind of a hard ride from the tire shop back home, but then I've only driven it a couple of hundred miles?
I know I need to weight the front and rear of the unit and then check Goodyears Tire pressure guide for the 245/70/R19.5 tires, and I have to do that, but can't this week. I'm going on a short (less than 100 miles) trip in the morning. As a base, I'm thinking of the 82 PSI. When I weight it, I'll adjust accordingly.
Any thoughts?
2013 Mirada 29SE, I earned it!
Hugh R is offline   Reply With Quote
Old 06-20-2013, 03:22 PM   #12
_nelsonc's Avatar
Originally Posted by Hugh R View Post
Hey,
Any thoughts?
My 2013 Coachmen Mirada 35DL calls for 90 PSI so I am running that until I can get weighed properly. Your approach is the same as mine.
_nelsonc is offline   Reply With Quote
Old 06-20-2013, 03:32 PM   #13
Hugh R's Avatar
Thanks, just needed a little re-affirmation that I'm not missing the boat. Mine is a 29SE, so it would require less TP than your 35DL.
98 PSI just seemed way out of line!
Old 06-21-2013, 06:32 AM   #14
go6car's Avatar
We're still at 90psi as well - looks like that's where we'll stay too. Would love to weigh all four corners separately, but there's just no where around where I am to do that, so axle weights are our only guide, along with the sticker; and also Michelin's chart. 90 it is!
2013 Coachmen Encounter 36KS
(Forest River adopted cousin! )
2004 Jeep Wrangler
go6car is offline   Reply With Quote
Old 06-21-2013, 06:37 AM   #15
Herk7769's Avatar
If you try an pick a quiet day at the CAT scales, you can use the aft platforms and stop with the right wheels only on the scales. After they weight, reverse off. turn around and back onto the same two plates for the other side.
Don't try this on a busy day though.
HAM CALLSIGN - KC3FFW
Old 06-21-2013, 06:51 AM   #16
Originally Posted by herk7769 View Post
If you try an pick a quiet day at the CAT scales, you can use the aft platforms and stop with the right wheels only on the scales. After they weight, reverse off. turn around and back onto the same two plates for the other side...
You just have to make sure you are positioned the same way as far as how far over on the scales you are with the centerline of the coach. In other words, try to get the centerline of the coach at the edge of the scale both times.
Old 06-21-2013, 06:58 AM   #17
Herk7769's Avatar
Neil, I am not so sure this is critical.
The wheels don't know where they are at; just how much weight is on them.
No?
Old 06-21-2013, 07:07 AM   #18
No?
Try this some time, park both right side wheels just about 6" from the edge of the scales and then park them to where the inside of the left wheels are just 6" from the scales but not on the scales and the rh wheels are on the scales.
Might not be critical if the centerline of the coach is relatively close to the same, but it will make a difference if it is off by say a couple of feet.
Old 06-21-2013, 07:43 AM   #19
Herk, get out your diagram on how to weight the tongue of a trailer with a bathroom scale and a 2 x 4 and a block. I think it will clarify it somewhat.
Old 06-21-2013, 09:01 AM   #20
Herk7769's Avatar
So is this an issue with the CAT scale platform or where the wheels are placed on the platform?
Using your analogy of tongue weight using the bathroom scale, it would be like moving the entire trailer and setting up again. You are not changing the relationship of the wheels in relation to each other; just the location of the trailer in the "world."
The wheels will see the same load regardless of where they are parked.
The width between the scale and the brick does not change.
You are not moving the load INSIDE the RV around between weights.
