Old 04-15-2013, 07:36 PM   #11
Commercial Member
huntr70's Avatar
Originally Posted by RV Guy 5 View Post
1st let's not mistake TPO for rubber, the new TPO roofs are made with an elastic vinyl type of material and has a felt backing to them. This material has reduced the black streaks significantly. With the felt backer there is no more use of chalk under the roof, to move the rubber while it is stretched thus again eliminating the chalk residue that turns black.
Also since the TPO is elastic and is stretched it will move while the unit is flexing during travel. When a fiberglass roof is laminated to the backer the is no stretching or flexing that is allowed and may crack. If your fiberglass roof cracks it will be a significant cost for repair apposed to a patch over the TPO. A side note fiberglass that most manufacturers use is not supposed to be bent at a 90 degree angle to wrap around the side of your roof, make sure there is not a trim piece on top of the roof to puddle water from running off or leaks are likely to occur! TPO comes with a 12 year warranty against defects, what is your warranty on a fiberglass roof? 1 year possibly?
Winnebago offers a 10 year parts and labor warranty on their fiberglass roofs......do you cover labor or the material itself?
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 04-20-2013, 03:06 PM   #12
GM
bclemens's Avatar
Not to mention the vinyl has a felt backer...felt does what? absorbs water.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-20-2013, 03:33 PM   #13
Grape Escape
When I had fibreglass boats they took a heck of a beating. Never found it cracking.
Had a trailer with the vinyl roof and never had black streaks like I did with my 2 rubber roofed trailers.
Never again as it's a pita
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 10-01-2015, 01:50 PM   #14
Xhevoice's Avatar
Hi,
Do you travel with your cat? If yes, how did the cat adapt to it? How were you able to incorporate scratching post, litter box, toys, food and water bowls.
I'm Tanya, soon a newbie, researching my first Motorhome purchase and I will be traveling solo with two cats.
Xhevoice is offline   Reply With Quote
Old 10-01-2015, 02:42 PM   #15
breul's Avatar
Unhappy
I must be missing something?
Flagstaff 26ft TT
2013 Ecoboost F-150
breul is offline   Reply With Quote
