Old 11-02-2015, 08:51 AM   #1
hammer55's Avatar
Tst tire pressure monitor
Is this the one everyone has, or is there a different model, it doesn't have very good reviews, just want to make sure
thanks Hammer
ps: I could not post to the other thread, it was too old, sorry for the repeat question
http://www.amazon.com/Tire-Pressure-...ywords=tst+507
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 11-02-2015, 08:57 AM   #2
mcnabbwr's Avatar
That's the one I have only with the flow through sensors. Have not had a single issue with it in two years. It has saved me once.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 11-02-2015, 09:06 AM   #3
I have the same but flow through as well. It can take a little while to sync with the sensors when turned on so I turn it on when I start our teardown. It can be plugged in while driving but I found the battery lasts a long time. It also has a backlight that turns on automatically which is nice if driving after sunset.
A few times it has just lost the sync with a sensor while driving so the alarm goes off. Usually when I turn it off then back on it syncs up.
I even added a sensor to my self installed TV airbags.
gargoyle999 is offline   Reply With Quote
Old 11-02-2015, 12:55 PM   #4
WDW
3x we've got one too. Great service should you need it.
Life is always better under a Palm tree...
2016 Mirada 35BH "Trolley"
2016 Jeep Cherokee Latitude
Previous- Jayco Greyhawk 31FK
Western NY
WDW is offline   Reply With Quote
Old 11-02-2015, 01:10 PM   #5
We have that same one and have had good luck with it. The battery in the monitor went bad, they had me send it back to a new battery and they replaced the entire monitor.
Filthy Beast is offline   Reply With Quote
Old 11-02-2015, 01:42 PM   #6
dieselguy's Avatar
We've been running the TST system for 3 years and are completely satisfied. I've known a few people that got rid of their Hawks Head monitor, went with TST, and never looked back.
dieselguy is offline   Reply With Quote
Old 11-02-2015, 01:55 PM   #7
Tire pressure is what brought me here. We are interested in a tire pressure system such as the ones you all have been talking about because it would be greatly helpful in accessing the tire pressure problems we are having. But this is only one part of our problem. I will delete the rest of my comments about our tires not holding air steadily.
Susan R is offline   Reply With Quote
Old 11-02-2015, 02:20 PM   #8
geezer with gadgets
757Dave's Avatar
Here's the one that I use. No problems so far.
http://www.amazon.com/gp/product/B00...ilpage_o09_s00
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 48
757Dave is offline   Reply With Quote
Old 11-02-2015, 02:35 PM   #9
dieselguy's Avatar
Susan R ... you kinda hijacked this posters thread. You really should start a new post concerning your own issue. That being said ... I'm a country boy ... we have tire stores here that have water tanks big enough to submerge a tire and wheel in so the guy can look for air bubbles pointing to leaks. You may have a cracked wheel or some that have the wrong valve stem diameter installed. Tires loose pressure due to temperature and altitude on their own as well as over a period of time. Maybe you just have crappy tires if you're not the original owners.
Old 11-02-2015, 02:43 PM   #10
Former Full Timer
Duckogram's Avatar
TST-507 w/flow through sensors here. Been using it for over 3 years. Saved my bacon with a leaking rim on my 5er. I bought it through greatrvproducts.com Great service, price and support. Check him out.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
pressure, tire
