Old 05-26-2016, 07:15 PM   #21
Just installed last week. Will be going out here in a couple of weeks. Will be testing on some 7% grade hills with my toad hooked up. If you don't mind what did an alignment cost you so I can get an idea.
2016 Pursuit 33BH,
2012 Jeep Wrangler,
2013 Honda 50CH
Blue OX
cberlanga is offline   Reply With Quote
Old 05-26-2016, 09:48 PM   #22
Former Full Timer
Duckogram's Avatar
The alignment was done at Northtrail RV, a high end RV dealership. The base price was $200. Add the cost of shims to increase the caster and labor to re-center my Safe-T-Plus and my total tab was $275.00. The difference in handling was very noticable.
The recipe for perpetual ignorance is:
Be satisfied with your opinions
and content with your knowledge.
Elbert Hubbard
Old 05-27-2016, 02:03 AM   #23
pashooter's Avatar
I had an alignment done at a local truck shop back when I first picked up my rig... and before I installed my Safe-T-Plus. Made a big difference. Can't recall the exact price but it was in the same ballpark as yours Duckogram.
2016 Coachmen Pursuit 31BD
2015 Jeep Wrangler Sport Toad
Nights camped in 2017: 3
pashooter is offline   Reply With Quote
Old 05-27-2016, 04:59 PM   #24
Pretty much what I suspected.Any work done on a MH starts in the 3 figure range. Alignment check is next on my list. Thanks for sharing your costs.
2016 Pursuit 33BH,
2012 Jeep Wrangler,
2013 Honda 50CH
Blue OX
Old 05-27-2016, 05:07 PM   #25
Oaklevel's Avatar
Just be careful a tuner voided my warranty on my truck.
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 05-27-2016, 06:15 PM   #26
pashooter's Avatar
Details? The X4 tuner (one of the 5 Star options) lets you revert to the factory tune if you even need to take your rig in for service.
Old 05-28-2016, 08:02 PM   #27
Former Full Timer
Duckogram's Avatar
Just for clarity, the addition/modification of the oem PCM programming/setting
MAY void your warranty for the items directly affected by that change. There is a consumer protection law that requires the manufacturer to show how that change caused the premature failure of the affected part(s). With that being said, the cost of battling the deep pockets may cost more than fixing whats broke yourself. What it does not do is void your entire warranty so if you are confident in your ability to deal with the issue and you know where to take it for service, you will be fine.
Also noted is the vehicle and type of tune. The application of the tune on the 6.8L V-10 is quite different then the diesel application. The topic pertains to motorhomes only.
Elbert Hubbard
Old 05-28-2016, 08:11 PM   #28
Former Full Timer
Duckogram's Avatar
The alignment on my baby Benz was $10.00 more.
Elbert Hubbard
Old 05-29-2016, 11:08 AM   #29
Oaklevel's Avatar
Well yes & no some of the vehicle computers will store the last data from weeks............. Ok if there is no warranty but cost me a turbo.
1966 Mustang GT
1986 Mustang SVO
Old 05-29-2016, 01:18 PM   #30
pashooter's Avatar
So you had "tuned" a diesel, I assume? Most diesel tunes are designed to get more power (or torque) from the engine, so I can understand the OEM being hardnosed about that. The 5-Star tune for the Ford V10 is more about changing shift points for a smoother ride, but in either case it's definitely a possibility that having installed a tune could jeopardize a warranty claim.
